67S with 69S pistons
I'm going to get JE to make me up a set of 81mm
pistons for my 67S. I like idea of using the 69S
pistons.
Anybody done the calculations of what octane rating
to use with single plug?
69S had front mounted oil cooler I believe, will the
engine air baffle mod be enough to keep this thing
cool in normal street use?
andy
Old 04-29-2009, 02:04 AM
304065's Avatar
Andy, see my thread where I consider and do exactly this. . .
Jugs and Slugs: Confessions of a JE Piston owner
69S pistons are the same as 906 but they dont come in 81mm I don't believe. I do think Mahle 81 are available as 10,3:1.
Here's the problem: our small bore and deep combustion chamber make it difficult to get high compression without detonation on single plug. In order to get 9,8:1 or higher the dome of the piston has to be pretty big, 38 cc or more. This results in comparatively poor flame propogation around the "bump."
In the end I settled on 9,5:1 as a compromise between the original and the S, something that I could run on 93 R+M/2 "gasoline." Also, this car will be operated during high ambient temperatures in the summertime, so that's definitely a factor in the compression and octane decision.
With regard to cooling this is something I also considered and decided NOT to build the engine larger due to the need for external cooling. I had the oil cleaner ultrasonically cleaned and will use all new hoses, and have a fan with a 1,8:1 ratio center (not for concours but I have another original), I suppose you could also use a later style fiberglass shroud with the channel to feed more air to the oil cooler. Also, my case has piston squirters and the oil bypass mod, both of which help with cooling.
Hope this helps!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 04-29-2009, 07:08 AM
Thanks John, it does help. As usual you have thought things through
for your own build before I have even asked them. I should remember
to check through your old posts in future.
I will read the thread again but looks like I should go for 67S style
pistons.
andy
Old 04-29-2009, 04:12 PM
