-   -   Ring gaps (http://forums.pelicanparts.com/911-engine-rebuilding-forum/470409-ring-gaps.html)
jbone 04-22-2009 11:29 AM
Ring gaps
I'm building a short stroke 3.2 w/ Weber 46s w/ JE 9.5 pistons. Does anyone out there recommend a ring end gap?
jpnovak 04-22-2009 01:31 PM
Use the ring manufacturer's numbers.
My last set of rings had an end gap based upon a percentage of the cylinder diameter. Of course, they were custom made and I sent them the bore measurements so they came out ready to install. Yes, I verified ring end gap prior to installation.
JE typically use Total Seal rings. Are you using something different?
Flat6pac 04-22-2009 06:39 PM
I put a set together last month and the info was in the JE box. I have a recolection but prefer not to quote it
Bruce
BURN-BROS 04-22-2009 07:15 PM
The spec for the SC 95mm top ring is .007 gap. I doubt you can get that with rings provided by JE. I have found them to be normally around .012.
jbone 04-29-2009 10:08 AM
Thanks all. I've ended up w/ .012" - .014" on the top ring, a tad more on the bottom two.
