-   -   engine intermitent miss after rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/470535-engine-intermitent-miss-after-rebuild.html)
87 clubsport 04-22-2009 10:45 PM
After rebuild my 87 3.2 found intermitent miss, feels like no power like running 2 cylinder, suddenly power come back, already change speed and reference sensor,also CHT sensor, try both Steve Wong chips and factory chips no luck, also get a 88 DME from a friend, also no luck, clean all the ground, still no luck, can any fellow pelican tell me which ground related to dme is it in tranny main ground or in intake runner #1 , also check spark plug gap 0.7mm and reference gap 0.8mm, please help, also when the car warm runs better than cold, and sometime run over potholes car miss again, any input welcome. thanks.
Eagledriver 04-22-2009 11:19 PM
If the engine wasn't run for a long time sometimes the fuel injectors stick closed and so you get no fuel on the cylinders that are stuck.
-Andy
87 clubsport 04-22-2009 11:34 PM
thanks Andy fuel injector also clean and balance, new fuel pump, filter, coil, rotor, caps . only the fuel pressure I havn't check yet.
Trog 04-23-2009 03:12 PM
I would look at the fuel injector bulkhead connector. If it's loose, then replace.
87 clubsport 04-23-2009 04:02 PM
Bulkhead connector is it mounted on rear shock tower yes it is loose, where I can buy this male female connector ? Thx
Trog 04-24-2009 07:48 AM
You can replace it with a 4-pin weatherpak... Lordco stocks'em.
http://forums.pelicanparts.com/uploa...1240584474.jpg
