-   -   Boosting at 2.7 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/470580-boosting-2-7-a.html)
tadel001 04-23-2009 07:52 AM
Boosting at 2.7
I have a 2.7 I will be rebuilding. It came from a 76 911. My preference is to rebuild this and put it into a 73 or 74. I would like to beef up the performance. What are some recommendations/expectations?
Steve@Rennsport 04-23-2009 10:51 AM
There are many things one can do to the 2.7 to significantly improve performance.
Two questions, though:
1) Whats your budget? (this is the biggie)
2) Do you require smog compliance?
tadel001 04-23-2009 11:35 AM
The budget is open ended. The amount of money dictates how long I take. I would rather take the time and spend the money to have a nice set up. With that said, I will be doing the rebuild and have never done that before.
This will be a "historic" car so no smog or emmission requirements.
Eagledriver 04-23-2009 12:56 PM
You can build a nice 2.7 RS motor but it will cost alot. It would be much cheaper to get a 3.0 engine put carbs on it and have a bulletproof motor with more power and much longer life.
-Andy
rodoredas 04-27-2009 09:13 PM
yeah I'm looking to do the same, rebuild a 2.7, I'd be interested to hear what Steve@rennsport has to say my plans
I have Euro spec 75 911 2.7 but with S pistons (8.5 compression), yet I still have the non-S Cam's. I can see some opportunity to increase performance while retaining the k-jetronic fuel injection, but not a lot. They are - S Cams and SSI heat exchangers with either single or dual outlet muffler. There is not a lot of difference between the base level 911 cams and 911s cams but some. SSI heat exchangers look like they will offer some performance improvement.
Steve - any other ideas?
cheers
