Santa Clarita, Ca.
Question Adjusting cold start system
Anybody know how to adjust a cold start system on a 77 2.7CIS? I'm trying to bring the idle up a little on the cold start.
Old 05-28-2009, 10:03 AM
Porsche's Love-em Live-em
The cold [warm-up] idle rpm is controlled buy the Idle Air By-pass regulator. Located between cylinder 5&6 intake manifold runners. No easy adjustment-replace it. Were assuming your fuel system warm-up regulator is working properly. Ck. it first?
Old 05-28-2009, 10:12 AM
Santa Clarita, Ca.
It seems to be. I get spray from the cold start injector. Don't know how else to check Idle Air Bypass regulator. The engine will start from cold but it idles very low (my guess about 300/400 rpm). I want to get more idle speed so I have good oil pressure on start up. After warmup all is good.
Old 05-28-2009, 02:16 PM
Just off the top of my head, the air bypass is suposed to show 35 ohms on a meter to be good
Bruce
Old 05-28-2009, 03:09 PM
Santa Clarita, Ca.
Thanks Bruce. Any idea what the tolerances are on that?
Old 05-29-2009, 06:43 AM
you can put a plug on eather side of the Idle Air By-pass regulator. If that makes no difference when cold, just replace it.
Old 05-29-2009, 08:49 AM
Santa Clarita, Ca.
OK, just to clarify (I can't find any documentation on the "Idle Air By-pass regulator"). Are you refering to the warm up regulator? If so, how do you plug up "either side" There's just one vacuum line. The other two are fuel and one is electrical.
Do you mean this part (I am calling the warm up regulator)...
Old 05-29-2009, 10:10 AM
Nice motor!
OK, just to clarify (I can't find any documentation on the "Idle Air By-pass re"regulator). Are you refering to the warm up regulator?
NO! "Idle Air By-pass re"regulator" again bolted to cly. #5 intake runner between 5 & 6
Old 05-29-2009, 01:05 PM
Old Member
You might try looking for Auxiliary Air Regulator also, goes by a couple of different names.
Clifton Brown
https://www.mancalamarketing.com
Old 05-29-2009, 01:23 PM
Santa Clarita, Ca.
OK, thanks. I think this is what you mean...
Old 05-29-2009, 08:22 PM
That's da one!
Old 05-29-2009, 08:39 PM
