micheloaks's Avatar
Flywheel Crank Oil leak advice - 2.2T
Hi I am new to 911 engine rebuilding and am refreshing my 71 T prior to selling and replacing all the parts etc recommended in Waynes' book, as well as rebuild carbs etc etc.
My issue at present is with the clutch/flywheel removed for replacing, there is oil leaking through what appears to be two dowel/pin holes at the point where the clutch/flywheel is bolted to the crank. Is this usual? or symptomatic of other more mysterious issues - i am trying to avoid splitting the case as it has good pressure etc.
Help appreciated - cheers Michel
Old 04-28-2009, 07:09 PM
micheloaks's Avatar
no suggestions?
Old 04-30-2009, 12:06 AM
You need a picture as your description is not concise enough although it sounds like oil galley plugs
Bruce
Old 04-30-2009, 07:26 PM
micheloaks's Avatar
oil leak photos
Hi thanks for the reply. I will post an image tomorrow once i have been at the mechanics for more money transfers.
Cheers Michel
Old 05-05-2009, 12:27 AM
