Should I repair this or replace?
Hi
The Impulse (Reference Mark) Sender holster has cracked :( For those in the know, would you suggest I attempt to get it repaired or should I hunt for a replacement (and where should I look for one of these puppies?) TIA again Rolandhttp://forums.pelicanparts.com/uploa...1241520095.jpg |
What car, what year?
From the looks of it, I would say replace. I would
3.2, 1985
might be a tricky part to source? |
It must be replaced - they are readily available.
The P/N for the reference sensor bracket is 930.101.089.01 and the host has it listed for $165.
You need to replace it, its too hard to get to and it has to be right..least you have the easy part done, pulling it to identify the problem
Bruce |
Thanks guys. thought that part was an after market sensor. Big relief!
Cheers |
| All times are GMT -8. The time now is 04:07 AM. |
