Weber Jet advice
I would like your advice on what size jets to run.
Track only car. Weber 40's 2.0L six 69S spec heads GE60 cams 10.5:1 Pistons Race gas 36mm choke tubes 1.5" headers Thanks David |
I don't have jetting sizes for you but regardless of what you get you'll find each engine is a little different and you'll want to dyno tune or buy a wideband O2 guage. I just put a guage in my car and found an excessively rich mixture. I was able to quickly tune my carbs to a much more optimum AFR.
-Andy |
36mm venturis on a 2.0 litre seem a bit on the big side.
