-   -   3.6 ARP Head Studs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/473232-3-6-arp-head-studs.html)
VincentVega 05-07-2009 10:54 AM
3.6 ARP Head Studs
Quick confirmation.
The manual calls for loctite 639 on the head stuts in the case. However the ARP doc's say use the special sauce, ARP assembly lubricant.
Is proper application ARP Assembly lube at the case and the bolt end?
RSstop 05-10-2009 06:59 PM
Chris,
Use loctite only at the case end.
ARP assembly lube only on the head nut end.
Lyn
EBS_Don 05-13-2009 09:39 AM
Hey there Chris!
Exactly; LocTite on case end, lube on nut end. Make sure to follow the directions on the back of the box for torque!
Don
