MrPerkles's Avatar
Send a message via MSN to MrPerkles
Missed gear change disaster
Hi Guys
In the last session on a LeMans track day I was on the rev limiter in 3rd and going for fourth and grabbed 2nd.I put the clutch in instantly but the engine spluttered to a halt and I knew it was a goner
I have pulled off the rocker covers, top look fine but the exhaust valves no1 & no4 have bent valves.The adjusters are wound all the way out why is this ?
Whats really worrying no4 lock nut has gone awol.
Really frustrating as I have only got my car back on the road after 6 long months fitting EFI
I will strip down for further investigation but does anybody know the procedure for changing rod bolts without splitting the case ?
www.facebook.com/pages/Bournville-Frameworks
Old 05-24-2009, 08:38 AM
I'm here to cause trouble
jimbauman's Avatar
Wow .... there must be some mighty strange physics going on there.
As for new rod bolts w/o splitting the case ... I haven't done that but people do. You can't use a stretch gauge, but torque to 50-55 foot pounds should get you there (assuming ARP).
Old 05-24-2009, 08:51 AM
safe's Avatar
EFI, does it have a tacho tell tale, so you know exactly what rpm you hit?
Magnus
Old 05-25-2009, 05:25 AM
MrPerkles's Avatar
I tried to get into the data log last night Safe but couldnt find the file.
I will take the ecu to the manufacturer sometime this week and find out.
Full top end tear down pictures of the carnage to follow very shortly
Old 05-25-2009, 05:37 AM
I had a less significant missed shift once...
luckily I only "kissed" the valve and didn't fully bend it.
but my adjuster also loosed and back off the same
I was told by a 2 mechanics that this is very very common
I found my nut in the lower valve cover
you definitely have to find it
get a magnent into all of the passages
brant
914/6 2.0S with twin plug
all metal body panels
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 05-25-2009, 07:29 AM
MrPerkles's Avatar
Bump for this info please guys "procedure for changing rod bolts without splitting the case"
Engines out and on a stand and ready to tear down,never rebuilt an engine before so a bit nervous
Uprated srprings are definatley on my priority list,further tear down will work out my full list of parts.Do I go 3.2ss or stay 3.0 with twin plug high comperssion,choices choices
Old 05-26-2009, 02:53 AM
MBEngineering's Avatar
HI MrPerkles
changing the rod bolts is not a prob' with the case not split, just use a 2nd person and a good screwdriver to hold the big end cap, then work the cap round the crank until you can remove it, if you have stretched things, just be careful the bearings do not drop in side when you pull the cap off, I would replace the bearings as thay have taken a beating, for the peace of mind and a little extra time I would split the case and check the main bearings also. if you want to give me a ring about the engine please do 015395 67959.
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 05-26-2009, 10:29 AM
MrPerkles's Avatar
Originally Posted by MBEngineering View Post
HI MrPerkles
regards mike
Ahh Mike Bert has told me all about you and I know you can build a mighty C3
I might do a part build but probably DIY as my budget is 10 northern pounds and a chicken.
I will strip it right down and post my findings on here but would love to hear your advice over the phone
Many Thanks Andy
Old 05-26-2009, 10:36 AM
HI Andy
I am still at work until 7.30 if you would like to ring, or are you at the Porsche auto jumble on Sat ?? is the chicken alive or roasted??if alive , looks possibly like a trade!!
regards mike
Regards mike
Old 05-26-2009, 10:44 AM
MrPerkles's Avatar
HI Andy
regards mike
Catch you at the jumble Saturday with that crazy Belgium guy
Old 05-26-2009, 11:16 AM
