b&b heat exchangers for 2.7 1974 911
I came across a set of B&b heat exchangers and muffler and the size is B&B 1 3/4" , there website specifies these for later model engines 3.0 3.2, would this fit my stock 2.7 1974 911 engine, please help
thank you ALL in advance
German
Old 05-31-2009, 04:24 AM
The biggest problem is the flanges are too thick for the early car, you ll need longer studs on the exhaust side and that work tends to be expensive because the old studs do not remove easily.
The later exhaust has inserts that fit into the head so the gaskets dont blow. The inserts in the exhaust pipes need to be removed or ground down so you can flush to the head.
You could do better.
Bruce
Old 05-31-2009, 07:34 PM
Thank you, I do appreciate the help. I think ill just go with the stock ones
Old 06-01-2009, 05:35 PM
