-   -   which heat exchanger would you use? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/477475-heat-exchanger-would-you-use.html)
Rols 912 06-01-2009 03:53 AM
G'day everyone
I have a dilemma regarding my 3.2 rebuild. I have two sets of exchangers:
  • a 3.2 set
  • a freshly jet coated set for a 2.2
The 3.2 has the thicker flanges + the extra length of pipe that stops the reduces the failure of the gaskets.
The 2.2 has the benefit of being jet coated ($400!)
Which set would you use?
TIA
Rhttp://forums.pelicanparts.com/uploa...1243853531.jpg
Aurel 06-01-2009 04:02 AM
I would sell both and buy a set of SSIs. Dilemna solved!
Rols 912 06-01-2009 05:24 AM
what are they worth?
Aurel 06-01-2009 06:14 AM
I`d price the dirty ones at $150-200 and the clean ones at $350-400. You can check prices in the PP classified section or e-bay. That might raise you enough cash for a pair of used SSIs. But other points to consider are emissions in your area, and the fact that you will still need a two in muffler for the SSIs and updated oil lines. Really depends on your budget. Otherwise I would use the thick flange after a good sandblasting and sell the thin flange.
