-   -   Pressure relief bypass sleeve (http://forums.pelicanparts.com/911-engine-rebuilding-forum/477538-pressure-relief-bypass-sleeve.html)
4sd911 06-01-2009 10:27 AM
I'm looking for some machine shops that will re-sleeve the bore for the pressure relief piston and the safety valve. I see that Competition Engineering does it any other shops. Preferred West Coast.
DW SD 06-01-2009 02:41 PM
just curious, why do you need that service? Do you have an oil pressure problem? What are the symptoms? On which Porsche engine?
Did you call Ollie's?
Doug
4sd911 06-01-2009 04:52 PM
High oil pressure. 2.7 engine. I was told by German Precision to get another case. Bores are pitted and there is some spring marks in one. Check out my other thread about decaying magnesium.
