-   -   Broken Head Stud (http://forums.pelicanparts.com/911-engine-rebuilding-forum/477725-broken-head-stud.html)
dk911 06-02-2009 07:42 AM
Broken Head Stud
Has anyone ever used this tool? Stomski Racing Exhaust Head Stud Repair Kit. or recommend replacing only the broken stud(s) and not all of them?
Flat6pac 06-02-2009 07:49 AM
I have used several tools of Stomski s and they all have worked as described. The oil cooler pressure tester, the circlip installer, and the shifter swivel to the trans.
If there is threads that are useable, why would you replace the studs, there is enough real work that needs to be done. I do believe in a set of burning tanks and torches.
Bruce
john walker's workshop 06-02-2009 08:23 AM
get the one from a quiet boom, here on pelican and save some $$$$.
lucittm 06-02-2009 05:07 PM
Since you asked...
I broke a few exhaust head studs and I replaced all of them with ARP studs, for my thick flanges the P/N's are:
(1) 400-8005, 4-piece kit and (1) 400-8015, 8-piece kit. This will cost you more than the stock M8x1.25x57mm studs, washers, and nuts, but you will sleep well at night knowing that you will never break another exhaust stud, I know I do.
Mark
