more chain ramps
Has anyone removed the brown chain ramp without splitting the case? My allegedly professional mechanic put the brown chain ramp outboard on the1,2,3 side and a black ramp where the brown one should be. I dont see how the black one will come out without splitting the case. Fwiw the engine ran great, although on inspection it appears the sprockets show wear. Any help/suggestions would be appreciated.
John
Old 06-05-2009, 03:05 PM
Yes. Just make sure you don't drop it into the case when you remove the bolt pins that hold it in place. After I removed the closest pin, I ran a wire through the ramp where the bolt goes through to ensure I could fish it out of the case in the event it slipped out of my grip and dropped in there after removing the inside bolt.
1985 redslope 930, 8:39 RP, S cams, B&B dual out muffler, IA Fuel Dist. Sitting on shelf awaiting installation: IA HF turbo, GSF headers(no heat), 46mm wastegate.
1971 911T Targa. needs alot of work(understatement).
Old 06-05-2009, 06:54 PM
