Mo money = mo parts
Has anyone tried these exhaust studs
A UK firm with stainless exhaust studs for aircooled Porsche and VW applications. They're a little cheaper, but more importantly I would think the stainless might hold up pretty well. I don't know if there would be any metallurgy concerns between alloy heads and the stainless.
http://cgi.ebay.co.uk/Porsche-6-Cyl-Eng-Stnls-Exhaust-Studs-Nuts-911-914_W0QQitemZ220372514174QQcmdZViewItemQQptZUK_Car sParts_Vehicles_CarParts_SM?hash=item334f39b57e&_trksid=p4634.c0.m14.l1262&_trkparms=|301%3A1|293%3A1|294%3A30
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 06-09-2009, 01:47 PM
Stainless steel set screws - good idea. Probably pricier than regular ss studs. I'd still use some anti-seize on the threads.
Sherwood
Old 06-09-2009, 02:43 PM
Manassas, VA
lucittm's Avatar
Be careful with the VAT and shipping from the UK, it is very high. Also, unless this alloy of SS is made for extreme heat, I would run away. Most common SS such as 316, 440, etc. will gall after exposure to heat making removal of the nuts very difficult.
You might be able to contact the seller, if he specifies A2 SS (don't tell him - let him tell you) then you will be fine.
Good Luck,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 06-09-2009, 07:35 PM
safe's Avatar
Normal stock studs hold up fine for many years, and with less risk. I wouldn't put stainless together with aluminum.
Magnus
Old 06-10-2009, 12:01 AM
Here's a related discussion in the Engineering Tips website:
http://www.eng-tips.com/viewthread.cfm?qid=166307&page=1
Sherwood
Old 06-10-2009, 12:15 AM
