-   -   Bead blasting heads (http://forums.pelicanparts.com/911-engine-rebuilding-forum/478984-bead-blasting-heads.html)
MrPerkles 06-09-2009 02:00 AM
Bead blasting heads
My heads are going for porting and valves guides etc,I have use of a bead blaster.Where is it safe to bead blast the heads ? all over or do I need to stay clear of the cam tower faces and barrel faces ?
88911coupe 06-09-2009 05:53 AM
I'm no expert but I'd definitely stay away from any of the sealing surfaces and obviously the insides.
cgarr 06-09-2009 06:23 AM
We bead blast all our heads, (all areas) glass beads have a very low probability of metal removal, in other words it will not change the dimensions.
MBruns 06-09-2009 06:46 AM
bead blast
We bead blast everything as well, just be sure that it is glass beads, and if you have a bit of gasket or some sealer on a machined area remove it instead of trying to blast a stubborn area for a long period.
Mike Bruns JBRacing.com
WERK I 06-09-2009 07:40 AM
+1
To remove soft pliable material of the head, it's easier to use chemicals. Combustion chamber's carbon build up, it works great.
MrPerkles 06-09-2009 01:50 PM
cheers guys degrease then in the blast cabinet tomorrow with a very fine bead
911pcars 06-09-2009 02:46 PM
Uh, no. Degrease them with liquid degreaser first. Use blasting medium to remove foreign particles like carbon and surface corrosion.
Sherwood
euro911sc 06-09-2009 03:51 PM
Just be careful how you move them around in your cabinet... You do not want to put scratches in the surfaces from your cab. grate.
-Michael
MrPerkles 06-10-2009 04:00 AM
Ok guys I will be careful but while I have your attention :)
I will be having a valve job and mild port carried out.I have Jenveys which taper from 48mm to 41mm would you open the 39mm inlets to 41mm or leave a step ?
BTW I have searched on here and read up on this but still cant decide which way to go
haasad 06-10-2009 04:56 AM
Blend
Mr P,
Blend them through, no question.
andy
WERK I 06-10-2009 07:20 AM
Blend them, no question.
Anytime there's a transition step, you stand the strong possibility of fuel dropping out of the mixture and causing uneven fuel mixture distribution, especially at lower RPM's.
