just purchased a 930 1989 and the cam tower has a little seapage??
just purchased a 930 1989 and the right cam tower has a little oilseapage I was told by the seller . can this be repared while a replace the Turbo with the engine still on the car?
Thnaks
Old 06-12-2009, 06:12 PM
BReyes's Avatar
In the 930/911 pulling the motor is not difficult.
If could determine exact location of seepage machine shop could certainly solve problem. The motor seems to be going into service. I would say no on the leave motor in, pull turbo, fix cam tower oil seepage issue. Can you pull motor, (builder)rebuild it it if necessary. You will probably be in top end rebuild territory to fix such oil leak.
1989 930 is tops !
Goodluck.
Bernard
Old 06-13-2009, 02:47 PM
Mine has the same leak. It was coming from between the cam towers and the cylinder heads. What really sucked was the leak dripped right on the header so every minute or so a huge puff of smoke would pour out from under the car. It was starting to get really annoying!
I ended up pulling my motor and will be doing a top end rebuild to include the heads, rings, rod bolts and misc re-plating and powder coating.
I decided not to split the case after removing the #5 rod and the bearing looked brand new.
Mind you, I had to remove one of my heads anyway to repair a bad attempt at a thread repair. So I figured I might as well freshen the top end. If I didn't have to remove the head I would have probably left everything as it were.
Old 06-13-2009, 03:39 PM
jluetjen's Avatar
Are you sure that it is not just leaking from the lower valve cover? It's an easy fix and I'd give it a try before pulling the engine out. I'd get a set of silicon gaskets and make sure that the valve cover sealing surface is flat. Clean all of the surfaces with brake cleaner and then put it back together.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 06-13-2009, 05:48 PM
Look at your rockers and make sure the rocker shafts are properly placed as they are oil seals. I have a hard time seeing mating surfaces , heads to tower as leaks if they were properly sealed.
Bruce
Old 06-13-2009, 08:09 PM
