Always learning
Correct fuel line diamter for a 3.2
Hi everyone
I have read through many threads on entire fuel line replacement from the tank to the engine.... After reading the posts I have become more confussed than ever. I was hoping to clarify some of these points once and for all in my mind....
For a 3.2 engine (running in a SWB):
I intend to replace the both supply and return lines with 8mm rubber fuel hose - is this okay?
I did read somewhere that I needed a 10mm supply and a 6mm return?
Is the rubber okay to use in the tunnel (wear)?
Your help would be greatly appreciated.
Roland
Old 06-23-2009, 05:44 PM
