Always learning
Correct fuel line diamter for a 3.2
Hi everyone
I have read through many threads on entire fuel line replacement from the tank to the engine.... After reading the posts I have become more confussed than ever. I was hoping to clarify some of these points once and for all in my mind.... For a 3.2 engine (running in a SWB): I intend to replace the both supply and return lines with 8mm rubber fuel hose - is this okay? I did read somewhere that I needed a 10mm supply and a 6mm return? Is the rubber okay to use in the tunnel (wear)? Your help would be greatly appreciated. Roland |
