-   -   Srp tensioner tool (http://forums.pelicanparts.com/911-engine-rebuilding-forum/481729-srp-tensioner-tool.html)
P Clingman 06-23-2009 04:50 PM
Srp tensioner tool
Hi all have any of you used the Smart racing tensioner tool I was thinking about
getting a set for adj cam timing it would save me from removing tensioners to
put mechanical tensioners in for the adjustment but I was wondering if they
tightened the chains enough. Thanks Palmer
Eagledriver 06-23-2009 06:21 PM
I'm not familiar with them. I don't know how you could adjust cam timing with the tensioners installed. They will extend when you undo the cam nut/bolt and you won't be able to colapse them unless you remove them.
-Andy
P Clingman 06-23-2009 06:56 PM
Andy you can remove the cam bolt from the cam without the sprocket coming off
the sprocket runs on a pilot if you hold the outside of the sprocket when the bolt
is removed you can remove the pin and reinstall the bolt and washer to start adjusting the timing. I have been using mechanical tensioner during adjustment
but that requires removing the other tensioners thats why want to try the SRP
tools. Palmer
