The head stud topic is one of those rare cases where the camps are so far divided. It leaves me scratching my head. Many stories of success or failure (except supertechs) of ARP, Raceware and factory 993tt dilvar. I will have to err on the side of caution and engineering principals and go with the 993tt studs. My last 993tt put down 600tq x 600hp on a stock motor and the heads never leaked. My current project will have less cylinder pressure so the stock 993tt studs should prove good. I would love to hear more from the big (800hp+) turbo builders on their thoughts. |
I'm doing a rebuild (3.2 with some mods)
Al things considered, I'll be ordering Supertec studs instead of 993 full threads. Even if one is better than the other, I'm quite sure that both kinds are more than capable of performing the task I want them to do. (holding heads, cilinders and case together) After hearing a lot of good things about Supertec and the fact that they come as a complete package (studs, bolts,...), for a very reasonable price.... I'll be ordering Supertec studs for my engine. If I had 993 studs already lying around.... that would be a different matter. |
When is the last time the Porsche head studs were prone to breakage the early 80's
regards |
I get a kick out of your passion for such a silly stud. If nothing else you must admit that the stud design strains credulity. Stress risers in the middle of the stud should give anyone reason to think. The key seems to be this notion that Dilavar expands with the same (similar) rate as aluminum. I have check ad infinitum and can't for the life of me find any specs on this magical expansion coefficient. Since no one seems to know (unless you have this number) what the expansion rate is how do you know that it expands at a better rate than Supertec studs ? For that matter any stud? Please enlighten me. Could it be that the material in my stud is just too expensive for the Porsche bean counters? If they had a choice with no regard to price would they use my design instead? Of course you can't answer these last question with any certainty but it's fun to ponder the question anyway. http://forums.pelicanparts.com/uploa...1265125540.jpg http://forums.pelicanparts.com/uploa...1265125551.jpg http://forums.pelicanparts.com/uploa...1265125560.jpg |
What's silly about this discussion is that it misses the main point, Porsche switched to Dilavar because the difference in thermal expansion rates of aluminum and conventional steel studs proved to be too much for the CASTINGS. 911 motors with cast iron cylinders do fine with conventional steel studs.
Take a look at the cylinder heads on a 2.7 with pulled studs. The cylinders will have pressed so hard against the sealing surface that they make an impression which must be machined away to restore a flat surface. I don't believe that the factory steel studs ever break, so why spend the money for the fancy Raceware, etc., which have the same thermal expansion rates? (I called Raceware and asked.) So, if you want to get a long life out of your head and crankcase castings, you'll go with Dilavar. If you just want to have a nice set of intact headstuds for a long time, you'll go with steel, factory or aftermarket. 300 engines Henry? That's what Porsche makes in a week. Oh, and they do have a few good engineers and a bunch of laboratories to test all this stuff. And they deal with warranty issues all day long, everyday. That said, the thermal reactors really were a disaster. |
Dilivar is a horrible material that never should have been used in automotive application. Porsche made a mistake. This is not unprecedented. Over the years they have made many mistakes (once again, IMHO) and what they planned for the Dilivar studs and what happened in the real world is miles apart. It's one thing to claim similar expansion rates and an entirely different thing to prove that their expansion coefficient is the correct one in real world application. As for your theory about 2.7 head damage, the stud is not the problem, Heat and the inherent weakness of the mag case is. When properly inserted and with heat under control, even a stock steel stud will offer adequate service. The question is "wouldn't you rather have better than adequate service?" There is a better choice but it requires that Ostrich like behavior be set aside. |
A good question to ask is why did Porsche keep coming back to the Divilar material after switching to steel? I know from my experience with air cooled aluminum Harley motors using steel studs the heads can leak when cold. It's not till the motors reach operating temps the heads are fully torqued due to the differences in the expansion rates of the materials. I have seen more than one guy blow head gaskets because they beat on the motor when it was cold. |
I'll bite, what are the trade offs. If you're going to elude to some mystic expansion coefficient, please list it. I have the numbers for my stud and can verify the expansion coefficient. Now my questions: What is the expansion rate for Dilivar and why is it better that the Supertec stud? These are simple questions that seem to get dodged constantly. This is a simple exercise in logic. Use whatever stud you want but if "you" plan on making claims be ready to back them up. I believe my stud is better because it offers design superiority: Torquing a fine thread nut offers more accuracy. All thread is goofy in that it leaves two stress risers in the middle of the stud. Allen nuts strip and seize on Dilivar stud do to corrosion and electrolysis from the proximity of heated, dissimilar materials. Dilivar studs require a very accurate installation height where as Supertec studs do not. This allow Supertec studs to employ complete thread engagement in the case. 12 point nuts far superior in quality to stock Porsche head nuts. Higher grade is the criteria I use to make this claim. Supertec head studs will never corrode and never break. Earlier someone asked if they should "reuse a Dilivar stud"? If you believe a Dilivar stud can be reused, I have a butch for sale. I aim to please so come and get them. I'll sell them for 25% of the best new price you can find. Hey Steve, here you go. Great studs at a great price!!! |
+1, Henry!
Henry knows his sh^t... why do some keep hammering on questions is beyond me...
Also one important bit of companion info from the same reference, that is rarely acknowledged..... "In addition the cylinder head bolts (edit....uncoated Dilavar...)are insulated by fibreglass, otherwise the cooling air flow would cause the temperature level of the bolt to fall far below that of the cylinder."....think cold engine moisture trap and corrosion cracking... And from BA's Performance Handbook (p77) - Dilivar 20E-6/°C "Specification of Dilavar as manufactured by DEW, Krefeld (edit...Deutsche Edelstahlwerke...) are as follows: Carbon 0.065% Silicon 0.200% Manganese 5.000% Chromium 3.500% Nickel 12.000% V+FE 78.650%" No datasheet is forthcoming on the DEW website.....perhaps a proprietary or customer specific alloy....(I doubt they'll respond for my request for one, but time will tell) Did a search of German patents and trademarks, but no hits on Dilivar or Dilavar... John |
All that aside, surely its not too hard to actually measure the expansion coeficient....a stud about 150mm long - more than enough gauge length to measure a change over about 100°C or so.
Henry - do I have this right for the Supertech studs.......1365MPa YP and 1462MPa UTS ??? now that's quality steel !!!! John |
Just a guess. It used to be that you could get the 993TT head studs at a pretty good price. Now, the price of those studs has nearly doubled ($35-$40 ea.) over the past 5 years making it the most expensive solution of the choices out there. Price vs. performance is no longer a consideration. Bottom line, it's your engine and your money. Consult with multiple reputable builders out there and go with it. You've heard from a couple, Henry (Supertec) and Steve (Rennsport) and they happen to disagree. Both are very reputable builders. |
Your suggestion about stud length when heated has no tangible value unless an equally accurate measurement can be made of the cylinder it holds. As I understand it (I'm a mechanic not an engineer) cylinders have different linear expansions rates but most cylinder manufacturers us high silicon content in their cylinders to prevent or at the very least reduce linear expansion. I would think your experiment would be of value from a researchers point of view but from a practical point of view, I believe that the difference between expansion coefficients is a minor issue at best. That's why my question was formed in two parts "What is the expansion rate for Dilivar and why is it [that rate] better than the Supertec stud? I have been evaluating & debunking Porsche myths for years in order to build a better/ more cost effective product. Just like the myth of boat tailing, the difference in expansion rates of studs is of little or no consequence in the function of a 911 engine. |
Hi Henry,
Here's the answers. I think that it is clear why the steel studs worked with iron and biral cylinders in the old 911s, and why Dilavar would be helpful where purely aluminum cylinders are used. These are linear coefficients, which should be the figures to use to determine the changes in clamping force on the heads. Material/ Coefficient of thermal expansion (10E-6/C) Aluminum/ 23 Steel/ 11-13, depending on alloy Iron/ 11 Dilavar/ 20 By the way, I'm a big admirer of your work! Tom |
The expansion and contraction rates for dilavar and aluminum are close BUT do they run at the same temp? As Henry pointed out the cylinders are high silicon so standard aluminum expansion rates don't apply. Because of the success of each has had (and other I have spoke to) with the two different materials this is one of those cases where there is no clear cut best answer. |
Henry - acknowledge your question was asked in two parts - and I only tried to contribute some "factual" info on the first part re material property.
I was only suggesting the coeficient of the Dilivar stud (alone, in isolation) could be simply measured to get an actual value (vs published or quoted number) - not the whole head,cylinder,stud,case system... But on that note, foil strain gauge, on a stud(s) , on a dyno, would tell you what s happening. John |
So how about getting some real life measuring done?
Thermal expansion - Supertec studs - 993TT, 3.8RS and RSR studs - regular steel studs - a Nikasil Mahle barrel - a Nickie barrel And then follow up with a strenght test of the studs with their respective nuts and specific fitting instructions (threadlockers / no threadlocker). Sure it's no massive test that simulates years of use and many many heat cycles.. But the raw strenght and expansion values of new studs should at least make for some kind of comparison that isn't about "he said that , but i say this, and the other guy is wrong" It's all mechanical, so it can be measured, right? |
Here's the explanation, in Mezgers' words, in 1972 (I don't know if he maintains this opinion today...)
The development of the Porsche type 917 car Hans Mezger, Dipl-Ing Proc Insts Mech Engrs 1972, Vol 186, 2/72 pp 17-18 "In general it could be stated that for the 917 racing car, steel is used only if and where titanium and other light alloys are not or less suitable. A special problem had to be solved in connection with the vertically divided crankcase and the mounting of the cylinder heads. The two-bolt connections are shown in Fig. 10. Magnesium and aluminium have a mean coefficient of thermal expansion of approximately 22E-6 to 24E-6 per degree centigrade. The corresponding value for titanium is 8.2E-6 per degree centigrade. The combination of a titanium bolt and a magnesium or aluminium part causes the bolt to expand only about one third of the expansion of the corresponding part. The 'cold' initial stress is thus enhanced by an additional expansion differential which will either induce a bolt rupture or a distortion of the magnesium or aluminium parts which in turn entails an undesirable reduction of the initial stress. http://forums.pelicanparts.com/uploa...1265230693.jpg (C) IME 1972 If normal steel bolts of a thermal expansion coefficient of 11.5E-6 per degree centigrade which is about half of that of magnesium or aluminium-are used, the difficulties are essentially the same. The solution of the crankcase and cylinder head bolt problem was found to be Dilavar. This is a special steel alloy having a thermal expansion coefficient of approximately 20E-6 per degree centigrade. When the engine is heated, Dilavar bolts will thus expand almost at the same rate as magnesium and aluminium. In addition the cylinder head bolts are insulated by fibreglass, otherwise the cooling air flow would cause the temperature level of the bolt to fall far below that of the cylinder." |
So now we need Dilivar case bolts. Please.......
The theory is well documented and beaten to death. My claim, weather you choose to believe it or not , is that the difference in the expansion coefficient at the temperatures achieved by Porsche engines makes no practical difference. The number for aluminum 23 is pure aluminum not silicon/aluminum alloys as used in all Porsche cylinders. As you know, there are many different alloys used in cylinders. I've seen numbers as high as 17 for stainless steel and numbers as low as 17 for high silicon/ aluminum alloys. 17=17 just a thought. So what is the expansion coefficient for Porsche cylinders? And once again why would a slightly higher clamping pressure on a cylinder head when the engine is warm be detrimental? If the EC of high silicon /aluminum cylinder was actually lower than Dilivar (possible?) wouldn't that be BAD ? I would agree that it is difficult to ascertain the one right answer. I do know that no one who has ever used my product has ever complained to me about that product. Can the same be said for the Dilivar head stud? I just got off the phone with a customer who rebuilt his engine with Dilivar and let it sit. Some time later he came back to his engine (it never ran mind you) only to find a broken stud. New Dilivar stud broke before the engine ran....... His project rebuild is on this forum right now and after removing the Dilivar his project now has Supertec studs. On the Forum right now......... |
Not trying to hose down your product, which by all accounts, has a great reputation for quality. Just adding some published, peer reviewed information, to the discussion. Regards John (PS I do not consider myself a peer to H Mezger, or even yourself in this regard) |
I am confused but is this thread about presenting information or defending a product? This is an reoccurring subject and I am curious, has it ever been resolved? What do the folks at LN Engineering say? Don't they recommend head studs to go with their cylinders? Raceware, APR do they have reps here defending their products here or is this just going to keep coming up?
Just for the record Henry your studs are in my engine and they have been fine, I did not build it, I just paid for it. John T. |
"The solution of the crankcase and cylinder head bolt problem was found to be Dilavar." Doesn't it also say "fiberglass coating". Later found to be a desaster. But without the fiberglass don't you run the risk of "the cooling air flow would cause the temperature level of the bolt to fall far below that of the cylinder?" I'm not sure but do Dilavar studs come with a fiberglass cover. :) You've quoted a remedy recommended by one guy, 30 years ago to repair a 1200hp 917, who had no idea what we know now. Dilavar is unstable crap. Quote:
John it has not been resolved. As mentioned before "there is no right answer". It is great fun agitating the animals caged by the "Porsche can do no wrong" myth. Charles @ LN makes billet cylinders (great product BTW) and billet aluminum has a different expansion rate than cast silicon aluminum. He ask me for some head studs years ago and I dropped the ball and never sent him any. I think I was low on stock at the time (as usual). I will let him answer the question of what he recommends. For all of you confused by this exchange, I'm sorry. I think the teasing has gotten out of hand. Buy what you want. For most applications anything will do and "will do" is good enough for most. |
For the record, there are many excellent choices that have been tested with our cylinders by various builders and end users:
ARP Supertec 993TT Dilivar Others I don't see as often, but I know they have been used successfully as well: Raceware Performance Developments All I care to see is an increased tensile strength over the standard steel stud with the Nickies. In our early testing, studs with tensile less than 190,000 psi (or thereabouts) would loose torque. My only complaint I have is that I do not understand the very high torque value provided by ARP with their studs. We threw out their recommendations of torques with the ARP 2000 head studs for the 356, 914, and VW type 1 years ago and settled on 24 ft/lb with them happily. |
I purchased a '78 SC with broken studs in 1992. At the time, the hot set-up was Dilivar on the bottom and steel on the top. I figured if Dilivar was better than steel I would use them on both top and bottom. I got the motor back together and in the car when I met my wife and moved from Florida to Texas. As you might guess, the 911 took a back seat to my new life. To this day I have never driven this car and only heard it run prior to pulling it down for the stud replacement.
It was stored in my garage and one day while sweeping up I heard a loud "pop" followed shortly by a louder "bang". About one minute later a second round of the same sounds, both coming from the direction of my old friend, the 911. I looked under the car as was very surprised to see two head nuts with washer and about two inches of stud lying on the floor. This was all happening with a motor that had never been run! The car was never outside nor was the engine ever allowed to get wet; ever. I think I paid $24 each for those Dilivar studs back in "92 which is about the same as what I just paid for a set of studs from Supertec. What I can tell you without reservation is that if looks have anything to do with it, the studs I got from Henry are hands down my favorite. The fine pitch threads on the nut end of the stud make torquing the heads butter smooth. In my opinion, Dilivar is useless in this application. If you build race motors that are going to have the studs replaced every six months, maybe. But if you're building a street motor or anything that will be in the car for more than a year, forget Dilivar. Like Henry, I have 22 "perfect" Dilivar studs for sale cheap. Any takers? Lindy |
Dilivar is Dilivar: the only difference between what broke in my car and that that comes from a 993 TT is the length of the thread. I don't think the question here is whether or not a particular stud will hold the head and cylinder to the case but rather, how long will it do this job? My experience (that's all I have to offer) is that Dilivar does not lend itself to a very long life.
Lindy |
"Old Formula" of course, why didn't I think of that? (he says as he slaps his forehead) All this time I thought we were talking about Dilavar but now I see we were really talking about don ta da..... Super Dilavar. New and improved Dilavar, able to leap tall buildings in a single bound. And yes, it does have a smaller Carbon Footprint, because we all know Porsche cause Global Warming. So if I get this right, all the specs posted above and in previous posts are suspect because they are the old formula? So if we are to believe that expansions rates are the single most important element of a head stud, what is the new and improved expansion rate? Take your time to answer, I'm ok, I'll wait :) |
Isn't it interesting how a recall for a rather minor issue becomes front page, almost "Global " news when the US government becomes a competitor of Toyota? The Trans Sec tells the American people to "stop driving their Toyota". WTF Of course there is concern, but a warning that "your pedal may stick, be careful and get it checked" should suffice for a thinking public. I would like to go on record as saying " I would rather push my Toyota than drive a POS Chevy!!!!" Rant over............ |
Henry,
You say you "researched" Dilivar and were able to find expansion coefficients and yet, someone on this forum found them. Everybody with any sense knew Porsche had the Dilivar studs redone when the 993TT came out. Yes, "dilivar is dilivar, it is an alloy created under a specific formula, but there is also a process of manufacturing an alloy that can make all the difference. The 911 3.0liter dilivar got their bad rap, deservedly so. Tell me, ol' wise one, how many 993TT studs have failed? Do your "research". I can wait, to paraphrase. :) In the mean time, take a anti-condescending pill, and wait a few hours to reply. I grow tired of your self-righteousness. |
Like I posted earlier "there is no right answer". It is great fun agitating the animals caged by the "Porsche can do no wrong" myth. Is rattling on the cage door working for you ? Because I'm having fun :) |
Dave,
How many 911 SCs do you think were rebuilt with Dilavar studs? How do you think that number compares with all of the 993 TT that were ever built? I don't know but I'll bet it's at least ten to one. I don't know anyone who has a 911 that hasn't either replaced there studs as a precaution or as a necessity. One of the reasons you don't see many 993 TT failures is because there aren't that many out there, comparatively. The 911 SC Dilavar stud got their "bad rap" because of what they were made out of, not because of an inferior manufacturing process. I think a 911 SC gets used a lot more like a daily driver than a 993 TT and is subjected to the environment and the real world. I think that's what this thread is about; the real world answer to the question "Would you use these"? Since Dilavar is known to fail as a material in this application, why would "anyone with any sense" use it? Lindy |
There are theories that failures were attributed to the coatings on the studs, and a failure by the vendor's manufacturing process. Pick any that may apply...... As Steve and Charles alluded to earlier, they have had good success with the RSR/TT studs. Are you saying they don't have "any sense"? These studs certainly see more thermal stresses and higher forces than an 180HP SC. I as stated in an earlier post, price versus performance, can't be used in an argument to use these studs. Over $800 for a set versus Supertec's studs, Raceware or ARP for less than $600. That argument makes more sense than RSR/TT studs are "bad". Don't know about the "daily-driver" theory. The 993TT is certainly more civilized, sophisticated than the SC, but then it also has AWD, more creature comforts. More all-weather than the SC. Right about the production numbers of the two breeds, but its been over 14 years......we certainly would have heard something by now if the studs started mysteriously snapping. Really, this debate has gone on a long time (too long). None of us on either side of the fence will waiver. It's your money and your engine. My last word on the subject........I promise. :D |
That's me, just another critter in the zoo. I always get a kick out of the name calling. When your agument fails, go with name calling. walking contradiction http://forums.pelicanparts.com/uploa...1265311523.jpg |
So after all the name calling and postering, self advertising and so on MOTLEY911 ever get his engine built? This thread has been going on since June and it's actually getting silly and a little insulting.
I want to know if anyone has ever heard of a 993tt head stud failing? Just curious. I have a motor going back together soon and have to make some decisions.
I guess you could google Stahl Motorsports in West Palm Beach, Florida and call or email him for details if you want more info. |
| All times are GMT -8. The time now is 05:16 AM. |
