Motor mounts one washer or two
Pet indicated 2 large washers for each side of the motor mounts. Bently says one.
Who is right! |
PET is correct. :)
Boy, I screwed up this question. I meant to say "transmission mounts". Must be the heat here in DC.
Your answer is correct for the motor mounts. The transmission uses the same part number as the motor mount. DUH! to me. |
Transmission mounts use 1 of those big curved washers on each side. :) :)
Thanks. SmileWavy
Until you get to the G50 then there is a special top washer with an indent in the center.
Bruce |
And to complete this thread:
How should the curved washers be oriented? Does it matter? |
Concave side towards the rubber part in the tranny mount bar, at least that's the way they go on the G50.
| All times are GMT -8. The time now is 04:28 AM. |
