head identification
we bought used set of heads want to know if they ar from a 2.2 2.4 or a 2.7. Intake valves are 46mm exaust are 42mm both ports are 35mm the head has a fuel injector
nozzel screwed into the head sorry no pic. also the casting inside the intake on two of the heads where the valve guide comes through is chipped, is this of any concern and can they still be used on my rebuild. my case is a 2.0 1968T will they bolt on without any mods. Looking for a few more ponies THANKS JIMMY AND MATT |
There is a casting date on the heads
If the injector screws in its for MFI engine. If there are no threads for the injector then its a 2.4T cis head These will only work on a 2.0 if you increase size with 2.2 P/Cs giving you the proper sealing surface for the cylinders to the heads. The guide will still support the valve even with the chip from an over zealous machinist Bruce |
| All times are GMT -8. The time now is 09:20 AM. |
