One more attempt at the connector thread...
Does anyone have a pinout chart/diagram for the wiring harness connector that plugs into the side of the 3.2 engine compartment fuse/relay holder?
http://forums.pelicanparts.com/uploa...1246733651.jpg |
Jim,
I can't help you with the chart/diagram because my 1991 wiring diagram is different. But, what I found out is that the corresponding connector that mates with the one in the picture will have the same pin out with the same wire colors. All you have to do is match the positions 1-14 with the positions that are filled with the appropriate colored wire . Also from your picture above I bet that if you start with - YE, GN, GN/YE, GN/WT, UNK, YE/UNK on the top row and - RE, GN/UNK, BN/GR, BN/BL, RE/UNK on the bottom row, you would be at a good starting point based on the length and the orientation of the wires. Good Luck, Mark |
I did a diagram not that long ago, but I can't find it now.
I tested with a resistance meter what the pins was connected to and used the Haynes manual to find out to what number in the connector it should be connected. |
Thanks guys. I ended up disassembling the other connector (being VERY careful not to let anything pop out!) and mapped it out. I did notice one instance where the colors didn't match up! Vagaries in wiring harness of the day I imagine...
JB |
| All times are GMT -8. The time now is 03:55 PM. |
