Dumb Oil Filter Q.
I have a 930 oil filter here (long story ) But my eng is NA regular 911 with a SC pump.
Can I use this filter ?http://forums.pelicanparts.com/support/smileys/chix.gif Thanx |
Probably a Mann OC54 used since 72 on all the 911/930
Bruce |
I got the filter from local P. dealer as I was in a rush to do this.....did not notice it said 930 on it till...too late (spin on ) So....usable or not ? there is a definite difference inside compared to the ones I buy from the host here.
Our Host has all sorts of springs and things , this one is all most all open, Dwn at the bottom there is a small spring sticking up |
930-107-764-01 is the correct part # for all 911 (1972-94), 911 Turbo (1976-89) according to Pelican.
I think that the turbos and NA cars used the same filters until 993's.
It would seem likely......Just the ones from our host has so many more parts inside it...The 930 is so simple , but maybe they are two diff brands
| All times are GMT -8. The time now is 06:41 AM. |
