piston sizing Question
i just bought some used p+cs on the outside of the cylinder there is a marking 95 zn1 ++w11
and the inside of the piston is marked 98 p11 the cylinder measures 94.95 across,roughly These where sold to me as Max moritz 98s...but i am just unsure why they are called 98s when the measurement across the cylinder is 95ish probably a newby Q .... and a second question will a fairly small dimple in the center of the piston cause any structual issues,( i can't get the camera to take a good close up) |
They are stock size cylinders. Did you measure the pistons. You'll have a hard time fitting 98mm pistons in 95mm cylinders. Someone could have bored the cylinders out, but not if they measure 95mm. The Max moritz pistons are 98mm and have a sloping flat face with valve pockets. The stock CIS pistons have a curved dome on them.
-Andy |
Pete
98P11's are the 3.2 Max Moritz short stroke pistons. Here's some data on a set I recently spec'd and sold: http://forums.pelicanparts.com/uploa...1247969965.jpg http://forums.pelicanparts.com/uploa...1247970062.jpg http://forums.pelicanparts.com/uploa...1247970116.jpg |
yup, that is what they look like, i will measure the cylinders more closely tomorrow
| All times are GMT -8. The time now is 05:18 AM. |
