-   -   What makes the CR difference between Euro and US 3.2? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/486400-what-makes-cr-difference-between-euro-us-3-2-a.html)
alniki 07-20-2009 06:17 AM
What makes the difference in compression ratios between Euro and US 3.2? Piston, head, or cylinder base gasket? They are 10.3 vs 9.5. Thanks!
tom1394racing 07-20-2009 03:06 PM
The difference is in the pistons.
The domes are slightly higher in the Euro version.
alniki 07-20-2009 04:49 PM
Tom, thanks! You are professional.
alniki 07-20-2009 10:05 PM
Also, I presume the CR has increased substantially with those thick carbon deposits on the piston doms.:) Possibly higher than the Euro 10.3:1?:D
