-   -   2.7 Cylinder (http://forums.pelicanparts.com/911-engine-rebuilding-forum/486750-2-7-cylinder.html)
Rainmaker 07-21-2009 09:59 AM
2.7 Cylinder
I guess I put this is the wrong forum
I have two 911/ 2.7 engines and need to make one.
Can I use 4) Mahle Cylinder/ Pistion sets and 2) Alusil?
Flat6pac 07-21-2009 10:55 AM
different weights, different deck heights. Look around and you can find the 2 nikisil you need. You want deck height on the cylinders and matched p/cyl
Bruce
