-   -   Ring End Gap (http://forums.pelicanparts.com/911-engine-rebuilding-forum/488668-ring-end-gap.html)
bullethole 07-30-2009 11:07 AM
Ring End Gap
Does anyone have a good tutorial (link pointer) etc for how to set the ring end gap. Advice etc.. would be much appreciated. Particularly for the diy without special tools etc.
Fast Corners 07-30-2009 11:25 AM
The JE pistons have a good write-up on determining the proper ring gap. The rotary style ring file works great and they are available even at NAPA (for < $100 IIRC). A couple words of advice. 1- Sneak up on the desired ring gap. Too many folks start "grinding" er filing away and the next thing they know is that the gap is now to large. 2 - Buy a nice set of fine honing stones to take the burrs off of the freshly filed ring gap before installing them on the piston.
OldTee 07-30-2009 11:34 AM
Look here and buy the tool.
http://www.muller.net/sonny/crx/rings/index.html
bullethole 07-30-2009 12:11 PM
thanks... a trip to napa is in the cards tonight. I figured this is one of those tasks that has to be very methodical and done a little bit at a time.. measure twice cut once.
