bad rocker?
Just putting the motor back together, assembling the rockers shafts and doing the valves when I came across this... Can anyone tell me whats responsible for a wear pattern like this? Unfortunately I don't know which cylinder it came off of. Are other rockers at risk? Can it be salvaged or reconditioned or replaced altogether? Anything I need to look at? Outwardly the cam lobes are all in good condition, should I be looking deeper? This was a total suprise, motor was running great when I pulled it apart for the head swap.... Thanks
http://forums.pelicanparts.com/uploa...1249941236.jpg |
Definitely replace it. All cams lobes are good? No marks. Were cam lobes checked by a cam shop? Did you remove the oil tube in the cam housing? You should make sure the holes aren't clogged.
If you aren't reconditioning the rockers and cams they are supposed to go back in, in the same position they came out as the cams and rockers wear to each other in the break-end phase of a new build. Mixing them up wil produce accelerated wear in the future. As for that particular rocker looks like it had an issue with hardening.
further inspection shows the lubricating holes in the rocker and bushing are misaligned... spray bar clog perhaps?
When you have a rocker that looks like that you will have a cam lobe to match...I guarantee it
Your spray bar has a plugged hole for oiling that lobe Bruce |
Was the rocker bushing frozen up? you said there were no oiling holes in it or at least not lined up? Otherwise if the rocker was resurfaced past the hard surface and not retreated it could have caused this too.
Bruce,
I'll be pulling the cams and spray bars tomorrow, new rockers on the way, hopefully the cam is not carved up although I'm not holding my breath. Thanks! Craig, The bushing is actually slipped and the holes no longer line up. Whether it slipped first and starved or was starved and slipped as a result I don't know yet. I suspect the spray bars will shed a little light when I yank them. Thanks! Tom |
What oil have you been using?
You had a piece of lint through the oil system and it just happened to stop at that hole
Bruce |
smoked the cam and another rocker. Looks like spray bar on number 6 is culprit... Can this be re-ground? It's dug into the lobe about .4 mm. Do the lobes in the last photo look suspect as well? http://forums.pelicanparts.com/uploa...1250005529.jpg
http://forums.pelicanparts.com/uploa...1250005562.jpg http://forums.pelicanparts.com/uploa...1250005578.jpg |
slyguy:
Yep, thats tosted pretty good. Cams could probably be salvaged by Web cams or some of the other cam grinders. Check 9xauto for rocker arms which are currently 39.00 each, which is cheaper than getting them reworked. Just a suggestion, I'm not an expert by any means. Good thing you caught this before startup, I can just imagine the racket this engine would have made. |
The cooked and aerated oil from the turbo goes back to the oil tank unfiltered in a 930. What really sucks is the stuff is everywhere throughout your engine, oil lines, and coolers now and you can only hope none of the piston squirters are also clogged. |
From the looks of the cam lobe, I would say it cannot be repaired unless you weld it up. Typically its the spray bar that causes this.
I have a core r/b SC I could grind to 964 specs for you, assuming from your sig this was a 964 cam. John |
I'm no fan of Castrol oils based on wear and dirt issues such as what you are experiencing. Further, coking is a problem with that oil in a 930. Just as Mr. Laifman said, you likely have such material in the rest of the engine based on what I've seen with engines running Castrol GTX as it makes quite a mess. At the very least, I'd be inclined to clean the spraybars on both sides of the engine. We send such cams to Webcam to be repaired and I always use new rocker arms. Its also very critical to break in the new or repaired cams properly otherwise the problem will recurr. |
Work up a price and time frame for me if you could, I'm at slivan@verizon.net Thanks! Tom |
We always remove the oil galley plugs in the crankshaft and scrub out all those passages, as well followed by ultrasonic cleaning. Do the oil coolers, too. |
from the right side spray bar, lodged in the spray openings. left side was no better...
http://forums.pelicanparts.com/uploa...1250033336.jpg |
| All times are GMT -8. The time now is 09:32 AM. |
