JE pistons rings
Hi guys
my engine is now stripped I only need pistons rods and springs I wIll do a full build update when i have all the parts. My question is I have found a set of new JEs 95mm that state JE rings for a $100 more I can buy JEs that state supplied with oem rings. Pros and cons please which should I buy ?,Advice appreciated
www.facebook.com/pages/Bournville-Frameworks |
The JE s that I used last spring said the rings were Goeteze.
Bruce |
The ones I just got had Goeteze rings (same as OEM)
Morning thankyou for your replies the pistons I have seen advertised have JE pro seal rings ?
My recent JE piston purchase came with JE Proseal, which were OEM oil seal rings and custom JE #1 and #2 rings...
