-   -   Camshaft Specs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/491863-camshaft-specs.html)
motley911 08-14-2009 07:35 PM
Camshaft Specs
Hi Guys, does anyone have the specs on the Porsche cams with the following part numbers:
993 105 246 70
993 105 247 70
I am looking for the normal information including the settings were they should be dialed in.
Thanks,
Richard.
Steve@Rennsport 08-14-2009 09:04 PM
Those numbers are not in PET and I'd guess the last two numbers got inverted. :)
The 07 cam are the standard 993 hydraulic ones. One needs either the factory tools and fixtures or use a solid rocker and manual adjuster on #1 & #4 to set timing. You can use the 964 spec if you use the latter method.
motley911 08-15-2009 07:30 AM
You are right Steve - I re-checked the part numbers and I had mixed up the last two digits. Correct numbers are:
993 105 246 07
993 105 247 07
I should have also explained, I am planning on installing these in a 930 engine with solid rockers.
Thanks,
Richard
motley911 08-15-2009 08:22 AM
Also - as I haven't been able to find any specs, I measured the lobe profile in the engine with a degree wheel. Listed are the results:
Total lift (zero clearance) = Intake 0.485" / Exhaust 0.446"
Duration @ 0.05" = Intake 242^ / Exhaust 225^
Lobe Centerline = Intake 114^ / Exhaust 110^
Intake valve timing (zero lash) @ 0.05" = Opens 7^ BTDC / Closes 55^ ABDC
Exhaust valve timing (zero lash) @ 0.05" = Opens 42^ BBDC / Closes 3^ ATDC
To get the "Intake Valve Stroke in Overlapping TDC with 0.1.. clearance" I then checked the WebCam and Dougherty sites for cams cams with similar specs and found the following:
964 = 1.26mm (as Steve suggested)
WebCam 20/21 = 2.1mm
Dougherty DC19 = 1.9mm
I could not find the actual lift / duration / centerline information for the 964 cams, so I do not have a good comparison to know if they should be set at the lower end (1.26mm) or if I should dial them in at the higher end (~2 mm)?
Richard
camgrinder 08-18-2009 11:58 AM
I have the 993 247-07 listed as a 1995 993 hyd rocker cam.
Your specs look closer to the 3.8 super cup cam, number 993 247-70
I have ground a few 993 cams to the super cup profile.
motley911 08-18-2009 09:34 PM
I just checked the actual part number stamped into the front of the cams and they definitely end in "70" and not "07". This answers a lot of my questions as I really wanted to know where to dial these in. I checked your website and the recommendation is 2.0mm.
I need to get a set of rocker arms rebuilt - I will contact you separately to arrange.
Thanks,
Richard.
camgrinder 08-18-2009 11:01 PM
Thanks,
Richard.
I believe the factory setting is 1.5mm for these cams. This puts them in the engine on a 114 intake centerline, or 2 degrees retarded from straight up. The 2.0mm setting puts the camshaft straight up on a 112 intake centerline.
