Were these rockers welded and ...
reground?? I was just doing my valves for the first time and noticed what looks to be welded rockers.. the cams are in awesome shape so whatever it is its working...
JP
'76 911s Ice Green Metallic bone stock
Old 08-21-2009, 05:59 AM
304065's Avatar
Somebody has installed a set of the early SWB rocker arms from a 2,0 liter engine in your car. They are forged and the rub face has a hard chrome coating on it, that is what you are seeing.
They have a slightly higher rocker ratio than the later cast ones, they are lighter, but they also are so strong that if you over-rev the engine, they will not break when the pistons hit the valves, probably leading to bent rods or worse damage. The later cast rockers usually break when this happens, which can minimize the economic cost of rebuilding the engine.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 08-21-2009, 06:15 AM
It IS a 2.0l motor.. 1969. So is the cratering factory? Or were they reworked?
JP
Old 08-21-2009, 06:20 AM
Those are factory original for the '65-'68 cars; thats what they look like.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-21-2009, 08:57 AM
