-   -   Early forged rockers - any pointers for evaluating condition? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/492810-early-forged-rockers-any-pointers-evaluating-condition.html)
kenikh 08-19-2009 07:59 AM
At $40/ea to chrome the faces of a forged rocker arm, I'd like to know which of my rockers don't need to be sent out for rechroming.
Can anyone enlighten me as to what details might suggest a forged rocker needs this work vs. one that doesn't?
Thanks!
camgrinder 08-19-2009 08:31 AM
You will need a "Coating Thickness Gauge" to measure the chrome thickness. I think the magnetic type are the cheapest.
Most likely the re-chromed ones will end up with a thicker more consistent face vs. the used oem ones.
kenikh 08-19-2009 08:48 AM
Whoooooooooo BOY! They are EXPENSIVE! Even the magnetic pen type is $200! Ouch.
That's almost half the price of recoating them all!
Well, now to decide whether to use my forged set or my cast set. The forged ones have a slightly better rocker ratio, so am apt to go that way, but I'll puzzle this out today and have to make a decision.
camgrinder 08-19-2009 08:55 AM
I would call around locally. Sometimes crankshaft grinders will have this tool. Or maybe a chrome plater, or powder coating place?
kenikh 08-19-2009 09:01 AM
Will do!
304065 08-19-2009 11:39 AM
Thanks!
Kenik, why not save the early rockers and use the later cast ones? They are cheap, they break if you zing the motor and the rocker ratio doesn't really make a difference. That is what I did.
kenikh 08-19-2009 12:14 PM
That's what Camgrinder said! :)
Will probably just do that, then.
Flat6pac 08-19-2009 01:29 PM
The forged rocker, if you jump time wastes the engine because they dont break.
aws 08-19-2009 01:30 PM
Kenik: The early forged rockers are much lighter than the cast ones. ( 109 grams versus 135 grams for the cast ones) They will not break with higher spring pressures associated with running over 8000. if you are interested in selling the set please PM me.
aws
