-   -   Magnetized intermediate shaft? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/493034-magnetized-intermediate-shaft.html)
4sd911 08-20-2009 08:48 AM
Should the intermediate shaft be magnetized? Mine is and there are some metal bits clinging to the inside. Any easy trick to get them out?
MBruns 08-21-2009 05:42 AM
magnet
Find someone that has the wet type of magnaflux inspection (aircraft engine shop) they will have demagnetizing equipment for post inspection. then you can clean it properly. One other source is a good crankshaft grinder, Armando at CCR in Ca. can help you.
Mike Bruns JBRacing.com
4sd911 08-21-2009 11:05 AM
Mike, do I assume that it's should not be magnetized?
MBruns 08-21-2009 07:26 PM
magnet
thats correct, it needs to be de magnetized
Mike
4sd911 08-21-2009 11:57 PM
Thanks Mike.
chris_seven 08-22-2009 12:45 AM
If you can demag to around 2 Gauss it would be good.
