-   -   3.6L rebuild options (http://forums.pelicanparts.com/911-engine-rebuilding-forum/493523-3-6l-rebuild-options.html)
e3photo 01-04-2011 07:33 AM
Well, I rechecked after the bolts were torqued. I went in for a snack, came out and put the chain tensioners on and timing chain cover, and I spun it around and checked again, before removing the dial indicator setup. I think I got it right, but it took a while.
I then started putting putting it back together. New rockers and lifters and new valve covers. I am about where I started, because the engine came as a long block. It will be fun going forward and seeing what I am missing.
Thanks for the input.
Emeraldhttp://forums.pelicanparts.com/uploa...1294155215.jpg
e3photo 02-06-2011 07:17 PM
Well, it is slowly coming together. Time to start figuring where all the wires go, and install the distributor. I know it needs to be at TDC to put the distributor in, I just need to figure out which TDC I am at.:rolleyes:http://forums.pelicanparts.com/uploa...1297048615.jpg
http://forums.pelicanparts.com/uploa...1297048656.jpg
