| Registered Join Date: May 2008
				Rings, brand
			Looking for some input on piston rings for a 2.7 CIS. I just bought a set of goetze rings and the end gap is to big compared to the new spec,  measuring comp 1, 0.016", comp 2, 0.025" & oil, 0.017". I understand there has been some problems with the goetze rings. How good is the quality of deves rings? Thinking of going with something different than the OEM goetze. Any suggestions?
|  08-24-2009, 01:12 PM |
| Registered |
			This is in new cylinders?  If not are you sure the cylinders are in spec?
				__________________ Robert Currently Porsche less (but the wife has 2) | ||
|  08-24-2009, 01:30 PM |
| Registered Join Date: Oct 2008 Location: Nash County, NC.
			I wouldnt run a moped on Deves rings, they tear the walls off of nikisil Bruce | ||
|  08-24-2009, 01:33 PM |
			Good, no on deves.  There are used, with my measurements, the worst clearance between cylinder and piston is .004", granted I don't have the best measuring tools. | ||
|  08-24-2009, 02:13 PM |
