-   -   Head crack at guide (http://forums.pelicanparts.com/911-engine-rebuilding-forum/494057-head-crack-guide.html)
4sd911 08-24-2009 07:06 PM
Head crack at guide
Just recieved the heads back from the shop. One has a small crack at the point in the head at the exaust valve shown in the photo. I assume this isn't a big deal? Right?http://forums.pelicanparts.com/uploa...1251165938.jpg
Flat6pac 08-24-2009 07:14 PM
Youre right, there is enough metal there you wont have a problem with it. I ve seen splits from original and sometimes there is chips out from the install of the guides.
Bruce
4sd911 08-24-2009 09:05 PM
Thanks, I just want to be sure, tomorrow the shop will be calling to see if parts arrived OK, I won't mention it.
