-   -   Exhaust Studs-Block Use Loctite/Antiseize ? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/494363-exhaust-studs-block-use-loctite-antiseize.html)
Number1_dog 08-26-2009 06:24 AM
I have all my exhaust studs out.
Should I use any thing on the threads on the studs going into the block.
I will be using anti-seize on the threads that stick out of the block.
Flat6pac 08-26-2009 05:17 PM
going into the block..youre changing the dilivars out
The studs will seat to the bottom, I usually clean the hole and put them in dry and tight. I could see using blue loctite, not red.
I like to grease the threads before I install the heads so I can get a good torque moment.
Bruce
dalematt 08-27-2009 12:00 AM
Hmmm, I don't think your exhaust studs stick out of the block, most stick out of the heads. Get some of the good high temp 1800-2000 degree copper anti-seize compound. Should be available at most of your FLAPS.
dm
Number1_dog 08-27-2009 05:40 AM
Yes, you are right it is the heads, but since everything is all together as a Long Block I faux paux'ed
dalematt 08-27-2009 06:05 AM
I brain fart often.... Wasn't picking at you, just said it to clarify since I understood you and the first reply mentioned dilavars...
I'm probably two months from the long block stage, still waiting on and ordering parts.
Enjoy!
dm
mca 08-27-2009 10:18 AM
For the exhaust studs ... just use anti-seize on the exhaust nuts (or thread of the stud).
I was told NOT to use anti-seize on the threads going into the heads b/c you don't want the studs to come out while trying to remove the exhaust nuts in the future. When I tore my engine down half of the studs came out with the nuts.
I also used loctite on the thread going into the heads. Not sure if this is needed though.
