Gon fix it with me hammer
Anybody with PET handy?
Need a part check
930 101 915 00 / 930 101 917 00 Supposed to be a 3.0t engine case But i need to know if it's one of the original ones, that takes the old 6 bolt crankshafts, or a later one with the 9 bolts Also, does anybody know John Flynn from CA? sells parts on Ebay as karenamberbrandon ... Seems like ok feedback, but if anybody knows anything else.. i would appreciate the info... i'm thinking of buying stuff from overseas... thx in advance Stijn
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 Last edited by svandamme; 09-03-2009 at 01:14 PM.. |
thanks !
so not a Turbo case , but an SC
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Edit; woops too late
Stijn, You need the engine #. Like 930/50 930/51 for 1976 turbo and 930/52 930/53 for the 77's The numbers you give are for a 78 SC
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
i knew the type numbers, but seller did not provide them when i asked.
he insisted it was a 3.0 turbo...but no year. Peterfrans also noticed that the crankshaft main seal area looked to big to be an early case... suspected it was an SC case... and was spot on
930.101.914.00 Turbo case 6 bolt flywheel
Bruce |
