-   -   What is this bushing? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/495916-what-bushing.html)
LeakProof 09-01-2009 02:43 PM
One more question guys.
I found two of these bushings under my shroud. Not sure how many I should actually have? I'm thinking three total?
I think I lost one or two of them.
Any input would be appreciated.
Thanks,
Leakproof. http://i472.photobucket.com/albums/r...ananaz/034.jpg
BURN-BROS 09-01-2009 05:02 PM
I think those are the spacers for the ac bracket support. There should be two. They would mount on the two 6mm studs that are on the passenger side cam tower.
LeakProof 09-01-2009 05:29 PM
Indeed, I think I had two to start with. Seeing I have no more a.c. components do you think perhaps I could ignore these upon re-assembly? I thought there were only two!
Thanks,
Leakproof.
BURN-BROS 09-01-2009 05:44 PM
Sure, remove the two studs in the cam tower and replace them with with the apropriate bolts if you need it to be "factory".
LeakProof 09-01-2009 06:16 PM
Sounds like a plan,
By 2010-2011 I should be at that stage of re -assembly :(
Thanks, again.
