-   -   Can I use a 964 manifold on a 993 vram motor engine? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/497651-can-i-use-964-manifold-993-vram-motor-engine.html)
matty74 09-17-2009 03:29 AM
well I have solved the problem for now I have got a 964 intake complete with ecu and harness all working for 1200 bucks, thats aussie dollars too.
down track when I get used to the power of the 3.6 i'll rebuild it and go to PMO itbs and 3.8 with some nice cams so I did not want to go and spend mad $$ on vram.
thanks for the help guys apprciated
DW SD 09-18-2009 12:04 PM
Matt,
What did you do?
Doug
matty74 09-18-2009 02:08 PM
Got a stock 964 manifold, ecu and harness
