-   -   Removing Cam Sprockets 3.0 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/498348-removing-cam-sprockets-3-0-a.html)
KoenigsTiger 09-12-2009 08:46 AM
Hey Everyone, :D
Is it ok to remove the cam sprockets with just a 46mm socket and an impact, while holding the flywheel or pulley? I have Wayne's rebuild book, he says that chain may stretch or break... But it is an impact, I wont be using a breaker bar.... What do you guys think?
Thanks,
Gene
JFairman 09-12-2009 11:06 AM
Yes.
The impacts from a good 1/2" drive or 1" drive air impact gun with the big 46mm socket are too fast, powerful, and of short duration to spin the rest of the stuff so you don't really have to hold anything from turning.
E Sully 09-12-2009 02:31 PM
No. It's not the chain breaking or stretching that's a real issue. The tensioners do not work when the cam nut is turned in that direction. This could allow the cam to turn, pushing valve into piston while the crank stays in place. Not worth the risk in my opinion. I'd get the wrench. Might work but if it doesn't it could get expensive.
http://forums.pelicanparts.com/uploa...1252790943.jpg
dcriss 09-12-2009 03:27 PM
I Agree with Sully.
NO! Too much risk. Anyway, why not do it the correct way.
Flat6pac 09-12-2009 07:04 PM
Taking it off is not as important as tightening it. The cam is a cast Iron and too much torque will break the cam at the threads. You need to see what you are doing while tightening so you still need the crowfoot to finish the job.
Bruce
KoenigsTiger 09-13-2009 07:58 AM
Thanks for the replies guys! I was thinking of using the socket just for removal, until I get the proper tools... The socket wont fit on the left cam because of the tensioner. I'd have to remove the tensioners anyway...
tom1394racing 09-22-2009 02:50 PM
The impact wrench is the easy and fast way to remove the cam nuts.
I always back the valve adjustment screws out first to provide extra insurance that the valves and piston don't collide.
KoenigsTiger 09-22-2009 07:51 PM
Oh yeah. I got them off.
Guess what I forgot to do, after reading it at least twice in the book. Back off the adjusting screws... I couldn't wait any longer. But the pistons looked fine. I dont think there was any contact with the valves... The chains have to be replaced anyway when rebuilding... :)
Thanks guys!
Gene
Walt Fricke 09-22-2009 08:31 PM
Well, my ignorance has been bliss. I've used the impact gun for big nut removal ever since I got air (I think I had a 46mm socket for VW axle purposes or something). Never gave valve contact a thought. Never had any, either, that I could tell. On the left cam I just hold the idler down with a hand after removing the tensioner. Cam doesn't really move.
Walt Fricke
