-   -   difference between 8.5:1 and 9.3:1 compression (http://forums.pelicanparts.com/911-engine-rebuilding-forum/498629-difference-between-8-5-1-9-3-1-compression.html)
constaf 09-13-2009 01:23 PM
Gents,
I have been reading about 911SCs recently and just noticed that Porsche made 3 different compression ratio motors (8.5:1, 9.3:1, and 9.8:1).
I always understood that the 9.8:1 was the compression ratio of the motor in ROW SCs from 81 to 83 and that it generated more power than the standard 8.5:1 ratio motor found in US cars.
What about the 9.3:1 to one? Was it ever offered in US cars? Is it true that the Weissach edition came with it? Does 9.3:1 provide more power/torque than the 8.5:1?
docrodg 09-13-2009 03:45 PM
Not sure about if ti was on US cars.
All other things being equal a higher compression ratio means more power.
Flat6pac 09-13-2009 05:01 PM
The 9.3 was used on all 80-83 with the lambda, it continued using 8.5 on the euro until the 9.8 arrived in 81.
Bruce
