930 crank
Hi All
here is an easy one for those that know, is boss that the flywheel bolts onto the same length on a 930 Turbo crank the same length as a normal 911 crank, that is does a turbo crank project further out of the crankcase than other 911 cranks , I am interested in the version that uses nine bolts to secure the flywheel, thanks Bill. |
| All times are GMT -8. The time now is 03:38 PM. |
