Santa Clarita, Ca.
Question Crank bearing oil journals
Just wondering...
I'm getting ready to send my case to the shop and was wondering why the oil outlets on the other side of the case are not drilled? Is this a modification that should be done?
Old 09-20-2009, 03:54 PM
The bearings are oiled from the other half of the case. I don't know of anyone that has done the mod you suggest.
-Andy
Old 09-20-2009, 05:43 PM
After a closer look at the picture it looks like the holes you circled are at the bottom of the case. Most of these throughbolt holes are not pressure fed with oil so all you'd be doing is bleeding off oil that could be used to lube your bearings.
-Andy
Old 09-20-2009, 05:46 PM
marks
What you are looking at is the oil holes from the bearings that were in that half of the case that transfered a witness mark to the case, as all the (2 thru 6) bearings have oil holes in them.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 09-21-2009, 06:43 PM
