How long will oil be shiny after rebuild
Hi,
I recently had my 1985 911 engine rebuilt by a local shop.
After I drove it I drained the oil and it had a "shiny" look to it, a metallic sparkle which I assume is normal after a complete rebuild. Haven't had a chance to drive it much but this weekend I took it for a spirited drive for about an hour and found the same amount of sparkle in the oil after draining it. Thinking the worst I opened the oil filter and much to my relief found nothing in it.
However I'm concerned that with a total of about 200 miles on the engine and two oil changes the oil still has these sparkles in it. You can't see the bottom of a plastic container if the oil is about 1" deep.
Oil pressure is great. 5 bar at 3000RPM and 2 bar at idle when hot so that's also pretty good from what I read.
How long should I expect to see this? (Can't rest and the rebuilder told me this was pretty normal and that I should leave the oil in longer after that first change).
Old 05-17-2010, 07:52 PM
this brings up a question, which has probably answered here somewhere, does the filter take out all particals that are harmful, the ponit being all the oil should fairly quickly go through the filter
Old 05-18-2010, 06:52 AM
You did change the oil with non-detergent? You need to run non-detergent for 1000 miles and you will see the metalic in the oil at that change, you may see it longer.
Old 05-18-2010, 08:13 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
is any of the sparkle from the assembly lube?
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 05-18-2010, 09:20 AM
Subscribed! On my 3rd oil change after full 2.7L rebuild and got the same thing going on...probably 300 miles on it. Identical discription though.
Thanks,
Nabil
'71 S track car, 2.7L & Webers forever!
Old 05-18-2010, 10:33 AM
AlfonsoR's Avatar
Hmmm, what's the micron rating on the oil filter?
Old 05-18-2010, 03:28 PM
notmytarga's Avatar
The material in the initial oil changes is not necessarily metallic/aluminum etc. Assembly lube is the most likely content. The filter apparently doesn't take it out - it probably becomes less viscious when mixed with oil and warmed.
I am due for a forth oil change. I'm at about 5000 mi - 2 years.
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016
<ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07
Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted.
2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon
Old 05-18-2010, 03:37 PM
Manassas, VA
lucittm's Avatar
A suggestion that made it easier for me to sleep at night - an oil analysis. It seems expensive but the report you will get is full of good information about a much more expensive investment, your engine.
I used these guys but there are others:
Blackstone Labs
It is even better if you submit several samples over a period of time because they review all your samples for trends, improvements after a rebuild, etc.
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 05-18-2010, 04:25 PM
dshepp806's Avatar
Staveleys , for me. Great oil analysis #s that are consistent. You'll get the metals breakdown that will correlate with specific component (wear)
She's gonna' want copious amounts of Zinc during her early seat-in (and oil change) period.
It would be quite interesting to get oil analysis data at tight intervals right after a full rebuild. I'd probably go anal about it and take 12 snapshots within 3K miles!!!!!!!!
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-22-2010, 05:26 AM
AlfonsoR's Avatar
Doyle
You like Staveleys better than Blackstone?
Is it recommended to add ZDDP, even to a good oil with 1200ppm, after a rebuild?
Old 05-22-2010, 10:19 AM
dshepp806's Avatar
Yes.
No.
Doyle
Middle Georgia
Old 05-23-2010, 05:06 AM
