How long did it take you to dial in a 2.8 MFI?
Hello all,
I'm at a crossroads with my engine, and what to do about the injection. The motor is a '72 with Mahle 2.8 RSR pistons and barrels, twin plugged E heads ported to 36 int & exh, MFI pump rebuilt by Gus to 2.7RS (that's what he wrote on the top), E stacks bored to 36mm, DC-60 cams, 1 5/8 headers, Dansk sport exhaust. (I think we figured it at 10.1:1). Now I'm temped to sell the MFI, buy TMW's, an EFI, and spend an hour or two at the dyno to call it good. Has anyone here tried to dial in an MFI with similar or other combo's? Realistically, how long does it take (assuming the guy dialing in the injection is good)? I understand MFI isn't as flexible as EFI, but would I be close with current parts? Thanks in advance. |
I do not have experience setting up the pump but since it has been worked on and tuned up by the master, I think you are almost there. It should not be hard to get it tuned, provided your throttles are in spec (butterflies and shafts not worn or your slides nice and smooth). Just need an air/fuel meter that can log data to a laptop while driving and then turn the adjustment screws a few times and that should be it. Just follow the Check, Measure, Adjust procedure.
A vintage, hotted-up, high-compression 2.8 RSR engine screams for MFI. There is nothing like it for throttle response and mechanical feel. Keep going on your original vision. :) |
The 2.7RS pump is tailored for the S cams and 8.5:1 comp ratio. Your 2.8 engine with 10.1:1 comp will require an adjustment of the main rack to richen it up and then a correction on the idle adjustment to lean it back. The DC-60 cams should be fine with the RS spec pump but the headers may be too big for good low end torque. I think you will get some very good results on the Dyno and the RS spec pump should dial in with fair results as long as you don't touch the black & white governor screws that Gus has set.
Don't be fooled into thinking 2 hrs on the dyno with an efi setup will suffice :) Unless this is a race only motor and drivability in of no concern, but even at that........
ITB's with a properly tuned EFI system has all the throttle response (maybe better) than MFI, and can be made to run nice and clean from idle to redline with enough patience....... :) Cheers |
Throttle response is about the same provided each system is functioning within it's parameters. Idle quality is usually better on the MFI system when running aggressive cams EFI will be, without a doubt more efficient across the whole rpm band. The closest I got to stoic tuning an MFI'ed car was a 2.4E and that was 13.2/1 @ idle and 12.5 @upper rpm. The vast majority of them ran the best with mid twelves at idle and low 12's at rpm. Tuning an MFI in the car can take as little as an hour and can go for days. It will totally depend on what you are willing to live with if there is a hiccup in the rpm band. My vote is MFI, but if you go EFI, get something with data logging as it is a great tool to have. |
If you're trying to set up idle on an engine with aggressive cams and ITB's and doing that on speed density, I'll understand (vacuum signal is non-existant and very noisy) but with Alpha-N? I've always got excellent idle and even on street cars that have 300+degree duration cams and have to pass local annual inspection and smog tests. Not as strict as CA, but nevertheless (max 4.5% CO) Care to go into details? |
Don,
I have a 914/6 track car powered by a 2.7L MFI engine. My engine is ported, GE80 cams, 10:1 compression. My MFI pump was prepared by H&R Injection as a race pump. It ran reasonably well out of the box, but it took me a couple seasons of tinkering to get the setup to the point where I was really happy with it. My car is used on the track only. My pump has three enrichment adjustments: idle circuit and main circuit (both as stock) plus a gross enrichment adjustment that is a race pump option that goes in place of the warmup enrichment circuit. I was able to get the engine close to right with just these three adjustments (the gross enrichment adjustment helps a lot, as it allows a much wider range of enrichment than the standard main circuit enrichment adjustment). But to get it really "right" I had to adjust the fly weights inside the end cover of the pump. This solved a mid-range leanness issue that I was not able to get rid of with the three enrichment adjustments alone. I did the fly weight adjustment on the advice of Hans from H&R. If you like your MFI, don't give up! EFI isn't exactly simple either ... Scott |
Scott,
Your engine set-up sounds great. I'm all for the MFI set up on all engines from 2.0 up to 3.0L. Above the 3.0 I think EFI / ITB's run better. Glad to hear your GE-80 cams are working well with the MFI. Is your "gross enrichment adjuster" the same as the one in this photo? I use it just to get the engine started. Don, I hope you stay with MFI. http://forums.pelicanparts.com/uploa...1253377687.jpg |
What's really neat is that MFI really is Alpha-N....just without lamnda correction. |
Thank you all for your input! i'm not so scared of putting the MFI in anymore, however the ignition is my next problem... who's got the cheapest twin plug distributor setup? Cheers, Don.
There is a basic adjustment I always performed on the dyno to see how the injection pump was going to work. Turn the man rack enrichment to the right in 5 click increments until the engine has a lean misfire in the stacks when you make a pull, then turn it back about 5 clicks. You can adjust the idle enrichment until it idles (no black exhaust) by turning that adjuster left to lean it out and it minimally affects the main rack adjustment.
Usually when things don't run well with MFI it is some other issue than tuning the main rack, like fuel starvation from the filter or tank, improper dwell, etc. I'd follow the CMA manual and leave tuning the injection pump alone for now. If you want to ditch the MFI let me know! It is without a doubt the best system ever used on a Porsche 911 engine unless you want to go full electronic. As for the distributor, Richard Clewett makes the best system which is crank fire based. You could go a cheap route and convert a 964 distributor for twin plug app. too. |
Sounds like good advice from cscrogham ...
In troubleshooting a tuning issue of my own MFI, I just called Hans at H&R Injection. A couple reminders from him: 1. Idle circuit is good for up to 2000-3000 RPM. 2. Anything above that is main circuit. 3. If you have the "extra" gross adjustment like I mentioned in my earlier post, it affects the whole RPM range, unlike the other two enrichment adjustments. As cscrogham notes in his post, remember that the two circuits are adjusted in opposite directions! Idle circuit goes richer by turning clockwise, whereas main circuit goes richer by turning counter-clockwise like a faucet. One other thing that messed me up once and is worth mentioning. MFI is sensitive to fuel pressure. It needs 15 psi or close to it, or it just won't run right especially under power. The stock fuel filter housing has a pressure regulator/limiter valve in the fitting for the fuel return (to the tank) line. That is supposed to keep pressure up, but over time the spring can wear out, resulting in pressure loss. I had this happen once, and it took me a while to discover that fuel pressure was the issue. The engine was breaking up badly in the mid and upper RPM ranges. To fix it I bought a fuel pressure regulator like the ones you find in Summit Racing catalog or similar, and now use that as a limiting valve in my fuel return line (I left the stock limiting valve in place since it now opens at only 10 psi). Scott |
Scott, You stated that the idle circuit was good for up to 2000 - 3000 rpm? Actually the idle circuit "#1 screw in the governor screw capsule" is good till about 1500 rpm then the #2 screw starts to take the spring load till about 3500 rpm then it's all on the #3 screw. Interesting note on fuel pressure. 15 psi or 1 bar at idle is great but more importantly the electric fuel pump must be able to flow over 1800cc per min through the MFI pump at high rpm's. I have seen fuel pressures as low as .1 bar at 7000 rpm's with no problem. IMHO The MFI pump needs the flow of fuel more than a set pressure of fuel.
Scott, Not 3 idle springs, just 1. Behind the cover plate that has the idle adjustment sticking out is the spring governor capsule. When you adjust your idle mixture by pressing in on the screw it is connecting it to the governor capsule screws. Photos below:
http://forums.pelicanparts.com/uploa...1253737700.jpg http://forums.pelicanparts.com/uploa...1253737742.jpg http://forums.pelicanparts.com/uploa...1253737774.jpg http://forums.pelicanparts.com/uploa...1253737791.jpg |
Sorry to get off track on your thread Don.
Cheers mate, Don. |
The pics that 356RS posted above show the adjuster screws for the "fly weights" as some call them. They allow more adjustment of the pump's enrichment if the external adjustments aren't getting you where you need to be. I had to mess with them once when I had a mid-range rich condition that I couldn't get rid of on my 2.7L MFI race engine.
Scott |
OK, lets fix this screw myth about "enrichment"on the spring governor capsule . The #2 black & #3 white screws are not for enrichment. I left out the #1 Idle. Although with some pump space cams, like the 2.4 T , they will cause enrichment in some areas, (Jeff's MFI Open Heart) but that's not what they are for. They are for setting up the predetermined spring tension on the flyweights ( different tension for different space cams) so at a given throttle & rpm the tip or sensor that rides on the top of the space cam is in the correct location of the contour or mapping of that particular space cam. These springs are checked and or adjusted by taking measurements off the main rack movement at certain throttle settings and pump rpm's. Below is a Bosch pump test sheet. "A" shows the correct setting of the springs required to put this particular pumps sensor in the correct location/contour on the space cam at different rpm's @ max throttle. "B" shows the 3 springs. This is the first check or adjustment that is done on the test bench when a pump is ready for testing.
http://forums.pelicanparts.com/uploa...1253814349.jpg If the pump was set up right "the 3 springs adjusted to the correct measurement" then when performing the flow tests you should see the correct amount of fuel "C" in the photo below. Notice the 2000 rpm @ max throttle in "A" and the same 2000 rpm @ max in the photo below: 7.00 mm on main rack full throttle delivers 47 - 48.5 ml of fuel in 1000 strokes of the pump. As long as the springs are set correct the sensor will follow the mapping contours on the space cam, the main rack will control the amount of plunger opening and you end up with the proper amount of fuel delivery from the MFI pump. I hope this explains the function of the 3 springs. http://forums.pelicanparts.com/uploa...1253814884.jpg http://forums.pelicanparts.com/uploa...1253816360.jpg |
Something tells me you've some experience in this area 356RS!
Is there any difference in fuel delivery due to adjusting the #2 and #3 screws? Or maybe movement of the fuel delivery curve higher or lower in the RPM range when these screws are adjusted? |
The best way to explain this is to show you what is happening to the "sensor" that is riding on the space cam. Remember, the job of the 3 springs in the "spring governor capsule" is to follow the contours/mapping on the space cam at different throttle & RPM's. The throttle controls the left and right movement of the space cam, and the RPM's control the fore & aft movement with help from the 3 springs and flyweights.
Photo below shows the sensor "U" following the mapping contour. The low tracks on the space cams cause the sensor lever to move the main rack forward and that causes the plungers to turn CCW on the left side of the rack and CW on the right side, turning the plungers toward more fuel delivery. If the sensor is adjusted so to cause it follow up the side of a contour, the rack moves the opposite direction and turns the plungers toward less fuel delivery, and goes lean. So you can see for example, the "E" space cam, if you adjust the #3 screws in CW, this will cause the flyweights to open up less, causing the space cam to not move forward enough, making the sensor "U" to ride up on a high side which is less fuel delivery, leaner. But look at the "T" space cam. Not much depth differences. Lots of room for error on mid and high throttle before things go bad. Now compare the depth of the "T" and "RS". The RS has quite the deep contour and that will move the main rack much farther than the "T" and turning the plungers more to get the needed fuel delivery of the RS. http://forums.pelicanparts.com/uploa...1253827250.jpg |
Thanks 356RS for explaining this ... so is it correct to say that while the fly weight adjustments (screws #2 and #3) don't affect absolute enrichment, that they adjust relative leanness/richness in their respective RPM ranges?
Well yes, #2 & #3 will affect fuel delivery in there respective RPM/throttle range when adjusted. On the 2.4T space cam adjusting the #2 & #3 clockwise, tightening up the springs on the flyweights, yields more fuel delivery. If you try to do the same adjustment on an "E" or "S" you reach a point were the sensor starts to climb out of a low mapping area and gets less fuel delivery. Hope I explained this OK.
I have been running my 2.7 for about 1000 miles now and still tweeking it. It is good and broken in so I will be going to a local dyno to get a baseline and some fine tuning but I made a lot of adjustments up to this point and corrected some errors I made early in the process. It helps to keep a notebook on where it is set and what you adjust. I also note the weather conditions as well.
The information in this thread and this site are invaluable to a DIY guy. MFI is very good when it is finally set correctly. It also sounds fantastic especially in tunnels and overpasses at full song. |
Twin plugs and compression have little to do with it as long as the timing gets set right.
A 2.7RS is 4% smaller than your 2808. Your GE 60 cam might flow more than an S but your ports are not any bigger than a 2.7RS so air flow might not be that much different. The easyest way to go is to call Gus, tell him what you are doing. He might suggest a starting point or sending your pump back to him so he can set it up on his bench. He needs to know your cam and exhaust as they are importang varables. Most the time, a pump he sets up is right out of the box. If it was a stock RS or an RS with a sport muffler as long as he know that, I would assunm his set up is right when delivered and if not right, somthing else is wrong. If you are a DYI guy, get the car on a dyno and moniter you AFR. A MFI pump is matched to the TQ curve, not the HP curve like other injection or carb setups. It should max flow fuel at peak TQ and not give any more fuel per stroke past that. This can make for a little rich running past TQ peak if your ports are small or exhaust is restrictive and TQ is falling off. If tuned for perfict AFR at HP peak you can run a little lean at TQ peak. Thus, look at the TQ curve and the AFR delta's. If they follow each other pretty well, you can just use the simple rack adjustment to get things right. If not, the sqrings and or weights might have to be reset and Gus should set your pump up for you. Note that different exhaust systems can cause more issue with tunning than compression, twinplugs, or the small bump is motor size you have. Not an expert, just what I belive. |
You really need a good AFR instrument to tune MFI. I have been reading all these posts and these gentlemen really know their stuff and they have forced me to think a lot about fine tuning my system.
I have driven my MFI 2.7 1973 100,000 miles, and in the last year have really gotten in running well with the help of these guys that have given you advice here, and a few others. Knowing AFR while you are driving and actually data logging it and studying it later is the only way to go. You can do it on a dyno, and even better is to permanently install an AFR instrument in your car and look at the data after you drive it on the street or the track. I will try to post a AFR/RPM graph for you. |
here is a chart. this is a 5 minute piece of a run. Seconds along the bottom, RPM on the left and in the red line, AFR scale on right. Green line is AFR.
http://forums.pelicanparts.com/uploa...1274573180.jpg |
| All times are GMT -8. The time now is 12:08 AM. |
