-   -   Classic 3.0 motor build? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/500127-classic-3-0-motor-build.html)
Shaun @ Tru6 09-20-2009 06:29 AM
I have acquired a core 79 SC motor, 930/13. tore it down to a long block yesterday and got it on the stand. From a basic visual inspection standpoint, case has been split in the past, 2 head studs have been replaced. I was going to just bolt on some early exchangers and Webers, but seeing as the case has been split, the amount of red gasket material on the exhaust and Alumablast on top of the case, have decided to make it a full tear down, inspect and build back up over the winter.
it's going into the 73T so I'm looking for an honest 200 to 240 (at the very most) hp.
Is there a basic spec to achieve this goal, one that's been built many times, tested and time-honored?
P/C and matching cams? I've got early exchangers, will go with new PMOs, and complete it with a M&K single out.
A friend of mine who has done 4 motors (and they still run) is managing the build and I'm more of the grunt work, parts running, cleaning, acquisition.
Given the vast experience here, are they any must-do's and tricks "while I'm in there?"
Tailgate on the 4Runner makes for a great workbench.
http://forums.pelicanparts.com/uploa...1253453137.jpg
http://forums.pelicanparts.com/uploa...1253453188.jpg
http://forums.pelicanparts.com/uploa...1253453275.jpg
jimbauman 09-20-2009 09:45 AM
You might want to invest in an engine stand and yoke.... the "tailgate" method of engine rebuilding has its drawbacks ... :-)
Shaun @ Tru6 09-20-2009 10:03 AM
Thanks Jim, yes, it's mounted on a stand and yoke now at my friend's house. I think we'll be tearing it apart next weekend.
euro911sc 09-20-2009 11:11 AM
If you are doing P&C's + cams anyways you might as well build a 3.2SS out of it. well known config. See P. 113 of Waynes book: start with a 3.0, get 98mm P/C's, 46 carbs, GE80 cam, twin plug heads, and BOOM There it is!
Wish I was building this car ;(
-Michael
jimbauman 09-20-2009 12:56 PM
+10 on the 3.2SS! But one comment to euro911sc - never ever use the word BOOM in an engine rebuild thread!
JB
euro911sc 09-20-2009 06:36 PM
LOL sooo right JB!
jpnovak 09-21-2009 09:39 AM
Here are a few routes that are generally accepted. They are ranked from cheapest (buy fewest parts) to most expensive. I would think that an early street/touring setup would favor the first or second one. Each example has its own documentation in the archives.
1) Keep SC 8.5:1 pistons and add 964 cams. Will extend rpm range a bit higher. Proven combination. Runs on Pump gas (cheap gas). Good low rpm torque.
2) Stock pistons and custom cam. Can maximize compression ratio and valve clearance for CIS pistons. Better performance than 1). Check with John_D about the possibilities. Mention you will run carbs. He can set overlap and exhaust lift to maximize induction.
3) JE pistons and Mod-S cam. Keep compression around 9.3 to run premium pump gas. Could go slightly higher at the expense of timing advance in summer. The NE might not be a problem. Benefit is large valve pockets. Cam upgrade for future track work is easy - no teardown.
4) 3.2SS. Expensive but worth it. Usually requires head mods (chamfer, twin-plug) and all the fun goodies. Can generally take as much cam as you want to throw at it. Make sure the oiling system is up to par if you want to run high rpm.
The road to the perfect engine has many paths. Each has its own destination depending on what you want out of the car and how much you want to spend.
canada911 09-21-2009 11:32 AM
Why on earth would one recommend GE80 camshafts for a street 3.0 build?
What a waste that would be, not to mention a very dissapointed owner.
I have a hotrodded 3.4 engine and Webcam 120/104 cams(similar to GE60), with PMO carbs,
and it is just streetable - doesnt pull hard until 4500 rpm.
I agree with the Mod-S cams ( at the most )
Just my thoughts.
Eagledriver 09-21-2009 05:41 PM
Your goals are easily attainable. Carbs, SSIs, Sport muffler: 220 plus HP. Carbs, 1 5/8 headers w/race muffler, Euro pistons or JE 9.8: 240 plus HP. These are configurations based on tested Spec 911 motors (note 1 5/8 headers and JE pistons are not Spec 911 legal, but we have tested them).
-Andy
Shaun @ Tru6 09-22-2009 05:16 AM
Thank you for all the replies so far, much appreciated. the 3.2SS is way out of budget so I won't be going in that direction. I have friends in Europe looking for good used 9.8s at a good price for me so I will go in that direction.
Any thoughts on a cam to match them?
BURN-BROS 09-22-2009 09:14 AM
I would not recommend anything higher than the 9.3 pistons. If single plug, I doubt you would feel the seat of the pants difference between the two compression ratios. A high percentage of 9.8 owners experience broken rings at the minimum and a very compromised ignition curve. I would recommend an octane booster if someone is stubborn enough to go this route.
If you are planning to go twin plug, then by all means 9.8's are fineSmileWavy.
wilke3169 09-22-2009 12:13 PM
My engine is a '79 3.0. I rebuilt 3 years ago. The engine now has 30,000+ miles on it. I used the JE 9.5:1 pistons, 964 cams, SSIs and a two out Monty. I dynoed it last November and got 187 at the wheels.
Just a little info to help with your decision.
Shaun @ Tru6 09-22-2009 03:42 PM
Aaron, got your email, thank you for responding to my inquiry. I already have the MSD so I'm a little ways there if I go twin. Going to see what turns up in the way of P/C which will really determine my path. The distributor is the one thing that hits rev limiter on the budget, but I've got all winter to pull the math together on that. Scope creep is a terrible thing. :)
Kevin, sounds like a great motor. Can you add some subjective experience, what you like, what you don't like, how's it feel, how fast does it feel, etc. Did you stay with CIS?
BURN-BROS 09-22-2009 04:44 PM
Ain't that the truth! BTDT.
wilke3169 09-23-2009 07:15 AM
I did keep the CIS. I really am pleased with the power. The power band is strongest from 4000 to 5500. Doesnt fall off above that but no real need to rev above this point, although I have tested the rev limiter on many occassions. I am still very pleased with the results.
I just added MSD this weekend. So far it just seems to smooth everything out. Wasn't expecting anything more than that.
Shaun @ Tru6 09-23-2009 04:33 PM
Thanks Kevin.
Aaron and others. I've located a set of new "Mahle motorsport 3.0 litre pistons which they supply for the RSR, we cc'd a piston and it came out to 9.7.1:1 with a 1mm head clearance in a 89.5 cc volume head. We wanted the original 'werks' compression ratio of 10.3:1 so have
gone with a different non mahle solution so the set are spare.
These pistons are new, still in their wrappers and packaging and ready to go with the rings, pins and clips."
My (extremely limited) understanding is that mixing piston sets and cylinder sets (I still need to determine if mine are good BTW) is not a plug and play affair.
can anyone please comment? thank you!
EDIT: So many here say to stay away from JE's for a street motor, but should I just go for JE 9.5s?
dtw 09-23-2009 06:11 PM
Verify that the wrist pin size of the new pistons will work with your rods.
Your jugs are probably Alusil, that just seems to be the luck of the draw. In which case, no, you can't put new Mahle pistons in them. You might get Nikasil jugs, but they'll have some wear. If using new Mahle pistons, I don't think I'd be able to live with myself if I didn't match them up with a set of re-plated cylinders. Just send yours to EBS and they'll do it. Doesn't matter if you send them Nikasils or Alusils.
JE is supposed to have a new alloy that finally 'works' on the air-cooled motors. However, I haven't heard any data coming back on these yet. Call around to the big shops and ask, if that interests you.
Another option is a set of QSC pistons/cylinders from Henry @ Supertec.
euro911sc 09-23-2009 07:19 PM
When I needed to match 1 9.8 euro SC piston to a cyl I already had it was a pain in the ass. I had to match the weight group for the pistons and then the diameter group for the cyl I needed to use. If you are buying new stuff or mismatched stuff just measure the hell out of the clearances and make sure it works with in spec. and you will be fine.
I run 9.8:1 CIS on pump gas all day long... however, I did blow the ring landings off a piston 3 years ago... resulting in see above ;)
BTW, I'm not recommending GE80 cams, just stated whats in the book ;)
-Michael
Shaun @ Tru6 09-23-2009 07:26 PM
Thanks guys, again, I hope to split the case with my friend Chris this weekend. Probably getting a little ahead of myself, certainly way ahead of my wallet. What we find this weekend will surely help set direction. Look for pics.
TibetanT 09-23-2009 09:35 PM
Subscribing.
Good luck with the build, Shaun.
